Engine swap - 225 from TT Quattro
How hard is it - I have an opportunity to buy a complete low mileage 2003 Audi TT Quattro from the breakers - front end damage and rollover - engine otherwise OK.
Warranty is offered on engine. Will it bolt right in or is it more complex than that?
I assume I will also need the ECU from the TT? also I would need the key programmed, right? Or can I just use the TT ignition and key?
Intercooler - I would need to buy an FMIC designed for the LCR?
Fuel? would I need anything not available in the TT? fuel pump etc.? CAI would be the same I assume?
All in all it seems to me to be a better option for tuning as the internals are different? im not too concerened about the turbo as I would change it later anyway.
A thought that just crossed my mind though - how hard would it be to take the Quattro system - is the rear suspension dramatically different? It won't be a bolt on affair i'm sure, but just how hard would it be?
