Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Its up under the dash on the linkage to the accel pedal arm, could it be the adjustment for the accel pedal height? As mine is quite a bit lower than the other pedals :shrug:
Thats the throttle adjuster. I wasn't getting 100% throttle so turned it a couple of turns and sorted.
I see, thanks :) How do you know if your getting 100% throttle then? Because i gave it a quick turn to see if anything moved, not sure if its back where it should be now :think:
Well i have an Apexi AVCR which tells me the throttle position. but there will be a measured value block within VAGCOM which ill tell you, not sure which block though.
Dam it! Why does everything lead back to VAGCOM?!:cry: (NOTE TO SELF - Buy laptop[B)] )
Cheers for the info :)
I've got the "WIRE". :lol: Try cable.
I'm a bit closer to you Beaker (Oxfordshire J6 M40).
PM if you want some help. :)
Regards Guy.
Cheers buddy, but i have got somone close by who may be able to help :D Just seems that whenever i want to do/check something on the car its always like "log block this, and read block that" I remember the days when a box of spanners was all you needed!
wire/cable whatever :lol:
I used to live in stroud so am often there anyway,
OK no probs. :)
what cable did you buy?
Built my own, look here.
http://www.tuning.it/elm327.php?l=e
Failing that try this,
http://cgi.ebay.co.uk/KKL-409-1-VAG...ryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or this.
http://cgi.ebay.co.uk/ELM-327-CAN-B...9QQihZ020QQcategoryZ30921QQrdZ1QQcmdZViewItem
If you're only using VAG-COM look here and start reading.
http://www.ross-tech.com/vag-com/cars/applications/index.html
Depends on what you want to do. :shrug:
Regards Guy.
No probs mate.
What's a spanner or box of 'em?
Guy.
Ok, checked throttle postion on my car today with VAGCOM, was at 90% on full load so adjusted it but it would only go as far as 96.1%. So checked another Cupra that we dont think has been messed with and that also showed 96.1%.
Is this right or should i see 100%?
Havnt driven it yet, not entirley sure how it was checked (new to VAGCOM), we just fumbled through the blocks untill we got a change in throttle position in % when i moved the pedal.
One word of warning, once you get it to 96.1% dont adjust anymore! As one more turn after that meant my throttle stuck to the floor after pressing!
