Its up under the dash on the linkage to the accel pedal arm, could it be the adjustment for the accel pedal height? As mine is quite a bit lower than the other pedals
Thats the throttle adjuster. I wasn't getting 100% throttle so turned it a couple of turns and sorted.
Well i have an Apexi AVCR which tells me the throttle position. but there will be a measured value block within VAGCOM which ill tell you, not sure which block though.
)Dam it! Why does everything lead back to VAGCOM?!(NOTE TO SELF - Buy laptop
Cheers for the info![]()
I have a laptop and can d/l the trial software, still need the wire though![]()
Try cable.I've got the "WIRE".Try cable.
I'm a bit closer to you Beaker (Oxfordshire J6 M40).
PM if you want some help.![]()
Regards Guy.
OK no probs.wire/cable whatever
I used to live in stroud so am often there anyway,
Built my own, look here.what cable did you buy?
Cheers buddy, but i have got somone close by who may be able to helpJust seems that whenever i want to do/check something on the car its always like "log block this, and read block that" I remember the days when a box of spanners was all you needed!
