that does sound good. i will scan my graph tonight and start a new thread
I'm not so sure replacing the oe actuator is worthwhile (just had a quick read of some past posts).
It's not the product itself, an improvement was noticed on a KO4 car but the car will need to be mapped again which will end up costing quite a bit of money in total for probably not much gain (if any).
Maybe if you're in the process of upgrading to a K03S then it could be worthwhile doing.
yeah, not worthwhile to do if you already have k03s i don't think. jabba said it was overkill really and isn't necessary unless your going K04 on the ibiza, wether it would make a difference on a k03s i couldn't say
The acuator is NOT a straight swap on a k03s. Forge will supply you with a Golf one IIRC and it doesn't fit. You have to cut your old acuator bracket off bodge that. So if it goes wrong you're screwed as you've just chopped you turbo up lol!
Forge could probably make a direct replacement if enough interest!
Its also listed under the Ibiza section so it should fit or the website should be changed
sounds to me like the forge actuator was fitted, which was then adjusted to its lowest possible setting - Jabba still wanted the boost lower than this but the actuator prevented this.
they then state "im a bit worried about the turbo veins but it should be ok"...
ok.. a worthwhile mod then...
The actual question shoul dbe what psi rating is the forge actuator setup with? what spring is in there? they are adjustable via springs just like DV's
lowest minimum boost (N75 @ 0%) is actuator pressure.... so a quick test to confirm would be disconnect N75 (electrically, it will pop a fault code) and see what gauge boost you see.
Difficult to see why a forge actuator would make more power, other than elevating the whole boost range by its higher preset spring rate. N75 duty cycle would be bleeding away x% more as a consequence with mike adjusting the scaling so limp mode does'nt ensue on deviations.
that high level of boost on a plain bearing K03s is mighty high mind... Completely flat out!
it probably does, but if it does goes bang it gives me an excuse to get an even bigger turbo doesn't it :D
ha ha, just got a £1760 xmas bonus :D only found out about it yesterday, if i had known earlier i would have got a K04 or AM04 instead of the K03s anyway!
