ive got some more footage now, its alot better but i cant find my lead for my digi cam to transfer it to the p.c.......gutted!!! The search party are in force!!.....
he's got:
Open Cone Induction
Forge TIP
K03's
007P
N249 Bypass...
All makes for a nice little wooosh!!!:)
:lol: What he said haha
Thanks :blink:
One thing is that my Open Cone Filter has no foam like a K&N would, its a metal type gauze....as Acid said above, you hearing an echo of the dump, therefore the less restriction you have for the sound the louder it will be, hence TIP and open cone filter (with no foam!), the K03s makes a nicer dump than the K03, and the N249 bypass just makes it crisp... :)
If you have a cold air feed CONNECTED to the end of your induction, the sound will emerge from wherever the end of the cold air feed is, I have TWO cold air feeds DIRECTED at the induction, therefore allowing the "dumpage" to come out the induction kit itself. The benefit of this is that the noise comes from the right area, its loud, and the induction kit gets plenty of cold air :D
Mike
I am very pleased with my SPLITR! Came in yesterday, I mounted it and tried it! On my car it sounds like BOVs on Lancia Delta Integrale! SWEET!
Whoos-s-s-s-h, in intervals!
Will try to film it!
I believe that in a week or two it gets even louder!
It will, mine has got louder over the last week as Ive been running it in. Gives off a very nice sound now & doesnt sound ridiculus
what about an dv30 or 007p
dont know about the dv30 but i know the 007p you notice more reversed
give the normal whoosh, but with a added "ting" or "sqeak" afterwards (like a loud metal on metal noise), hard to explain, some like it , some dont, only difference is fitting the dv in reverse relies on the spring
why would you fit it reversed? Is there any beneficial gains to be had by doing this?
Would this not be bad for your car?:confused:
because it gives a more "noticable"dv noise, only "some" people do it - some people dont notice the whoosh as much, but they cant not notice a high pitch squeek (i personally dont like it)
no its not bad for you car tho
