Following my previous logging session with std airbox (results here) 185.5 g/s, I refitted my Maxflow RamAir today. I'd bought a new core for it.
Here are my logs. Air temp 5 degrees, the only other thing is that following a tip from our sooty friends I put some dielectric grease on my MAF and N75 terminals. (same SP3 settings)
Things getting a bit warm by the time I did the following run (FMIC urgently needed) but now holding past 2bar over 6k....
You can really feel the difference in poke with the RamAir back on. It flies.
I wonder if 200g/s is achievable with a FMIC and some SP3 tweaking....
Code:
Sunday 4 February 2007
06A 906 032 HN 1.8L R4/5VT 0002
'003 '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC
/min g/s % °BTDC CF CF CF CF
2000 44.06 100 12 0 3 0 0
2160 57.14 100 14.3 0 3 0 3
2360 79.53 100 3.8 0 3 0 3
2640 99.14 100 0.8 0 2.3 0 2.3
2840 100.75 100 3 0 2.3 0 1.5
3120 107.83 100 0.8 0 2.3 0 0.8
3360 119 100 1.5 0 1.5 0 0
3560 129.64 100 0.8 0 0.8 0 0
3800 133.75 100 1.5 0 0 0 0
3960 140.61 100 3.8 0 0 0 0
4200 146.94 100 5.3 0 0 0 0
4440 155.72 100 5.3 0 0 0 0
4640 160.81 100 4.5 0 0 0 0
4840 166.44 100 4.5 0 0 0 0
5080 176.81 100 5.3 0 0 0 0
5280 183.81 100 5.3 0 0 0 0
5440 187.5 100 5.3 0 0 0 0
5600 191.83 100 6.8 0 0 0 0
5760 193 100 7.5 0 0 0 0
5920 196.25 100 6.8 0 0 0 0
6040 194.19 100 6.8 0 0 0 0
6160 196.25 100 7.5 0 0 0 0
6280 196.53 100 8.3 0 0 0 0
Code:
Sunday 4 February 2007 16:53:53
'115 Group B: '031
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor
700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar
/min % mbar mbar
2360 134.6 2280 1720 0.961 1
2560 172.2 2360 2220 1.008 1
2800 180.5 2460 2360 0.953 0.953
3040 182.7 2450 2310 0.922 0.906
3240 182.7 2370 2280 0.852 0.836
3440 189.5 2310 2330 0.828 0.836
3640 186.5 2310 2290 0.821 0.836
3840 185.7 2330 2320 0.828 0.836
4040 186.5 2350 2340 0.821 0.836
4320 185.7 2330 2340 0.821 0.836
4560 185 2310 2310 0.828 0.836
4760 183.5 2280 2280 0.828 0.836
4960 182.7 2270 2250 0.828 0.836
5200 184.2 2270 2250 0.828 0.836
5400 181.2 2290 2240 0.821 0.836
5560 180.5 2270 2230 0.813 0.836
5720 176.7 2210 2170 0.828 0.836
5880 173.7 2160 2130 0.821 0.836
6000 169.9 2130 2090 0.828 0.836
6120 166.9 2120 2090 0.836 0.836
6240 164.7 2120 2050 0.821 0.836
6360 162.4 2130 2040 0.821 0.836
