Who Says an Induction Kit doesn't make a difference?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Following my previous logging session with std airbox (results here) 185.5 g/s, I refitted my Maxflow RamAir today. I'd bought a new core for it.
Here are my logs. Air temp 5 degrees, the only other thing is that following a tip from our sooty friends I put some dielectric grease on my MAF and N75 terminals. (same SP3 settings)
Code:
Sunday	4	February	2007
06A 906 032 HN		1.8L R4/5VT         0002
'003				'020
Idle speed	Air mass in	Throt Angle	Ignit Angle	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC
 /min	 g/s	%	 °BTDC	 CF	 CF	 CF	 CF
2000	44.06	100	12	0	3	0	0
2160	57.14	100	14.3	0	3	0	3
2360	79.53	100	3.8	0	3	0	3
2640	99.14	100	0.8	0	2.3	0	2.3
2840	100.75	100	3	0	2.3	0	1.5
3120	107.83	100	0.8	0	2.3	0	0.8
3360	119	100	1.5	0	1.5	0	0
3560	129.64	100	0.8	0	0.8	0	0
3800	133.75	100	1.5	0	0	0	0
3960	140.61	100	3.8	0	0	0	0
4200	146.94	100	5.3	0	0	0	0
4440	155.72	100	5.3	0	0	0	0
4640	160.81	100	4.5	0	0	0	0
4840	166.44	100	4.5	0	0	0	0
5080	176.81	100	5.3	0	0	0	0
5280	183.81	100	5.3	0	0	0	0
5440	187.5	100	5.3	0	0	0	0
5600	191.83	100	6.8	0	0	0	0
5760	193	100	7.5	0	0	0	0
5920	196.25	100	6.8	0	0	0	0
6040	194.19	100	6.8	0	0	0	0
6160	196.25	100	7.5	0	0	0	0
6280	196.53	100	8.3	0	0	0	0
Things getting a bit warm by the time I did the following run (FMIC urgently needed) but now holding past 2bar over 6k....
Code:
Sunday	4	February	2007	16:53:53
'115				Group B:	'031
Engine Speed	Engine Load	Spec. Boost	Actual Boost		Lambda Factor
700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
 /min	%	 mbar	 mbar
2360	134.6	2280	1720	0.961	1
2560	172.2	2360	2220	1.008	1
2800	180.5	2460	2360	0.953	0.953
3040	182.7	2450	2310	0.922	0.906
3240	182.7	2370	2280	0.852	0.836
3440	189.5	2310	2330	0.828	0.836
3640	186.5	2310	2290	0.821	0.836
3840	185.7	2330	2320	0.828	0.836
4040	186.5	2350	2340	0.821	0.836
4320	185.7	2330	2340	0.821	0.836
4560	185	2310	2310	0.828	0.836
4760	183.5	2280	2280	0.828	0.836
4960	182.7	2270	2250	0.828	0.836
5200	184.2	2270	2250	0.828	0.836
5400	181.2	2290	2240	0.821	0.836
5560	180.5	2270	2230	0.813	0.836
5720	176.7	2210	2170	0.828	0.836
5880	173.7	2160	2130	0.821	0.836
6000	169.9	2130	2090	0.828	0.836
6120	166.9	2120	2090	0.836	0.836
6240	164.7	2120	2050	0.821	0.836
6360	162.4	2130	2040	0.821	0.836
You can really feel the difference in poke with the RamAir back on. It flies.
I wonder if 200g/s is achievable with a FMIC and some SP3 tweaking....:think:
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
fook me mate 196 g/s is very good mate, im only getting around 185 at the moment as im still running the stock stage 2 settings i think from when i was revod in 2005.
gazjones
that is good im seeing 187g/s with boost 9 timing 8 so i need more g/s
gazjones
erm 3's if i run octane booster i think but got those figures just on v power so its prob pulling back a bit will re logg with octane booster next week see if it improves. i wouldnt run those settings without a fmic though
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
dave, 196 is the max ive ever hit with a brand new filter, tip and fmic on :)
P-torque.co.uk
1,075
Wolverhampton
www.p-torque.co.uk
We are main UK distributors for the Ramair filters.
They do give great results, are are priced very well in the market. When we have the new rolling road in we will be doing some more in depth tests to see what gains they are acheiving.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
What you need to do (I think) is to find a reliable way to mount them in a VAG 1.8T. In my opinion the strut from battery tray to MAF just passes body shocks to the MAF.
My RamAir is currently sitting on it's own little cushion of bubblewrap bound in tank tape. :rolleyes: (and a flexible bracket to the suspension turret mount)
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
intresting.
im wondering if the dielectric grease played a part in this? when iused it on my maf connecter the car definatly responded better. power felt looser. like id removed a sock from the air intake.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
those are some galactic flow figures!
i didnt realise the k03s was capable of flowing that much, with the results iv seen first hand, healthy mafs on k03s equipped motors flowed no more than my k03 which iv had peak at 162g/s
DamoR
Smoked!!!!
Oct 9, 2006
726
Birmingham
www.myspace.com
News on a more robust way of mounting the ramair would be greatly appreciated as I just knackered a maf at the point which mounts the ramair bracket to the MAF. Strut top seems a good idea, raid should manufacture a bracket for this as they would sell well as an aftermarket part. This bracket could be added to all future kits as a standard item.
DPJ have you got a pic of this bracket?
