Engine Bay pic request
Hi, im looking for a very specific area of your engine bay, hence why i cudnt use the pictures from doing a search.
I want a picture of this area and where the bolted lead then goes!
FYI, a local garage took off my FSE power boost vavle on my request. But Didint put back on this vacuum lead, i think....
Thanks!
Jamin
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
I might be wrong but I'm sure there isnt one under my 1st spark plug. I dont think its ment to go anywhere because I think its not ment to be there full stop.
But as I said I might be wrong :(
Mig
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
Are we talking the yellow ring or the red?
The yellow is capped on mine as well due to me having a non-standard air box.
The red ring feeds back up to my ECU I believe. I had the same thing on my mk2 golf gti. This was to do with the Idle Stabilisation controlled by the ECU.
TBH my golf ran without this hose for ages and it never caused a problem, but i'm pretty sure that's what it is.
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
isn't the standard fuel pressure regulator built into the fuel rail? Im pretty sure this hose should go to the ECU as i think the fuel pressure regulators require a stronger vacuum from like the brake servos for example... I may well be wrong thou.
My experience with SEAT is limited but this engine does appear very much the same as my golf gti.
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
goes under the manifold and onto the FPR (fuel pressure regulator)
edited it to show roughly the route
and by heck its cold out there :p
