i was running settings 8,8 i told you to turn them down straight away mate!
also told you to check the 2nd actuator pipe as i havent removed the n112 on a standard turbo car before (actuator with 2 take offs)
HoocH
I've blanked off the 2nd actuator vac pipe on my k03 (along with n249 bypass), and it runs fine if that helps.
ok so im going to tsl on wednesday...
what stage 2 settings shall i run?
or shall i whip it back to stage 1 for the meantime
list of mods:
Miltec race cat
Miltec exhaust
4Bar Regulator
Jabbasport induction kit
Forge turbo intake pipe
Forge split r valve
Hmmm a crash. No mention of this when you sold it to us. What was the damage so we can keep an eye on things?????
What settings is the car running now?
i did mention it mate, i just buckled the front wheel when i hit a kurb, i replaced all 4 wheels and put a new driveshaft and wishbone on, no body damge occured what so ever, and the work was done at seat
all the settings are on the receipt i gave you with the car from tsl in nottingham
