Status
Not open for further replies.
as ive said the first lumpy graph could be operator error. and i dont really care how much these moderators claim to know there is no fault with this car, the car gets remapped on friday by another company and if m0rk is right then it will not make any more power than the revo one, however if i am right the car will make much more power, the car will be tested on the same rr immediatly after the map
the operator of the dyno was different in the two tests, now as your mighty mod says the second graph is ok. so that cannot be operator error
Should all possible options of what may/may not be the problem be looked at before slating?as mentioned before?
Also they gave you your money back,no questions asked,so surely no reason again for slating?Just a personal opinion.
guided fault finding... LMFAO. total waste of time then
logging is acceleration under load (like 4th gear) from low RPM to limiter while recording the measuring blocks
chuck your 1552 machine or whatever brick it is you're using & get a laptop with vag-com (and someone who knows how to use it)
lack of knowlege there bro?? its 5052, it is a laptop, and its third gear, as i said on friday if the car makes much more power would you agree the fault has been within the mapping??
God your a bit of a jumped up....
Obviously these people on here now nothing about these products and have never used them?
People offer advice and you throw it back in their faces and try and be the 'bigger man'.
not at all, i said my map was shite, which it was and these guys are adament that because the company is tried and tested the map cannot be wrong. as ive said, if the car makes shite power on friday, i will post the graph and i will eat humble pie, however i am confident that will not be the case.
as i said im happy im right. but as you chaps dont share my confidence then only friday will tell. now, m0rk, if the car makes more power after being mapped on the same indepentant rolling road then would you agree the fault has been within the mapping and the first lumpy graph was operator error???
put it this way
I'm not the one who works with cars all day proclaiming 7 years experience asking what's up with my car am I?
You're looking at a single figure on a dyno plot, which could easily have been frigged by a superchoops dealer. that plot is terrible, and not 'OE' at all. It's just not "right" regardless of what peak figure you have on there....
OE maps should be smooth in delivery without spikey lumps all over it.
3rd gear in a PD130 won't produce the load you need for reliable logging, so please - quit the jumped up "know it all" act and head back to work, pick up your machine and do the job properly
I don't understand what you're getting at?
1st dyno run you admit was run by a monkey at a Ford Tuners and was crap
2nd dyno was run at the same place by the same place which has proven to be unreliable as in 1st dyno plot
Check the figures at the bottom, the pressure's are totally different (well known trick to boost dyno figures)
I'm getting bored rapidly now
i never asked what was up with my car, as i know there is nothing up with it. now once again you havent answered my question, if the car makes more power on friday does the fault lie within the mapping?? and one other question. do revo not make mistakes??
thats ambient air pressure you dipstick, and yes same rolling road two different operators
I've pretty much had enough of you now.....
ambient air pressure can be 'adjusted' on dyno software to give more or less power....
of course unscrupulous dyno operators might alter this number to co-incide with their desired affect (like showing the post map difference as being much lower than it really was)
please read the post!!!!!! if the car had the 170bhp it was supposed to have why would i have taken it to get tested?? the reason the car was taken to be tested was because it had made very little difference so its not only the rolling road that thinks the maps shite i do too.
Status
