I previously owned a 2004 FR 20VT. I now have a 2006 FR TDi facelift model. On my 20VT I had the Autowindow module installed. I removed this and have been trying to install it in my TDi this week. The problem is that the colours of the wires have changed. I'm not sure if it's due to being a newer model or TDi but here's what I'm looking for.
Within the door of the 20VT there was a Brown wire with either a Yellow or Purple Trace. This wire should have a small amount of voltage going through it when the door is open and drop to zero when the door is closed. I have a multimeter however in order to test the wires I would have to remove the inner metal door cover which I'm not keen on.
The wires which go to the door latch are as follows:
2 x Brown (1 of which goes to the alarm LED - I take it these are ground wires)
1 x White with Purple Flash (also goes to alarm LED)
1 x White with Green Flash
1 x Blue with yellow flash (used on Autowindow already)
1 x Yellow with Blue flash (used on Autowindow already)
1 x Purple with yellow flash
1 x Green with blue flash.
My question is - Does anyone know which of the remaining wires replaces the old Brown/Yellow or Brown Purple? Would the brown wire definately be a ground therefore it would never have any voltage running through it?
Thanks, Brian.
Thanks, Brian.
