vag com newbie
blak ice
67
hi,
ive installed vag com 406(i think?) i have installed the drivers.
i did an open scan, but it did not come up with anything! I know for a fact that my car has at least 1 fault!!
the epc light has been on for months!!
when I do a controller module test it eventually says no response.
please help ASAP
blak ice
67
NO RESPONSE FROM CONTROLLER...YES i AM USING AN USB EBAY CABLE....THEY SAID IT WILL WORK OR MY MONEY BACK!!!:(
blak ice
67
any help people!!!!!
I have the free 1.
I jus wanna scan my car for faults.........please help
the interface is fine.
when i scan th modules the options in the bottom are disabled! and when i scan the egine-01 module...it says no response from controller![:@]
tompotts
Touch me in the morning!
Mar 17, 2007
269
Ive read somewhere about having to set vag-com into 'dumb' mode. I think that lets you read error codes but not program anything into the car. Apparently you have to set Vag-com to dumb mode if your using a 'dumb' lead, which I believe most of the ebay leads are.
Im not sure how you do this, but if you can find out how then its worth a try.
If Im wrong here someone please stop me, Im new to this too, Im just sharing what I think I know.
Hope you get it fixed.
Cheers, Tom
blak ice
67
thanks for your idea!!!
after nearly 100 views....are you telling me, that no one can offer any advise as to what my problem is?????
seli_babe
Don't Mess....
Nov 22, 2005
409
Bedfordshire
have you done the whole port thing???
check it on port 001, 002, 003 & 004... see if it picks up on any of them.. (I have an older version, so I dunno if it's applicable to the one your using... worth a try tho..)
(PS I have a ebay USB cable.. and it works fine in Mikes Ibiza, TonyK's and Festers Leon...)
blak ice
67
yea it works on port 3
it found the interface!!
this is really ticking me off!!![:@]
I jus wanna find da faults on my car with the cable i bought........
someone suggested that i change the baud rate...would this help?
seli_babe
Don't Mess....
Nov 22, 2005
409
Bedfordshire
Dunno about that mate...
If it's found it on a port then it should be able to check it, can you do any logs at all?? cause if you can then it should deffo be able to do a check on it.
Can't offer any more advice there mate, I've not come across this issue before.
Nov 2, 2004
9,334
South Wales
Make sure the COM port is set to the right one on the settings on VAG COM. Then hit test. I had to change my com port on device manager coz it was gettin conflictions with something else, then changed the COM port on vag com and it was hunky dorey.
tompotts
Mar 17, 2007
269
The Maf sensor, its a bit of the air regulatory system. All i really know is it breaks a lot. I know nothing else, google will probably tell you more.
kiearn
156
Norwich
Try using different drivers, change com ports and keep testing. I have to try the process of loading vagcom and turning the ignition on several times before it works sometimes despite mine now being saved with a serial number. [:@]
