Bubsy
88
Every now and again I get a picture of a sign appear on my multifunction display in the bottom left corner when I start up. Even thuogh I left it on clock when I turned it off.
A 2.0 with a picture of a turbo to the right of it.
Can someone tell me what it means?
are you sure its a pic of a turbo :think: get a picture next time!
have you checked the manual it has to have what it means in there
Checked the standard manual and the Cupra Appendix and neither have anything. It is actually a picture of a turbine fan.
It didn't happen this morning. I will try to get a picture next time.
Turbo fan LOL.
Its a picture of a snow flake. 2.0 means 2 degrees Celsius. Bet it does beep at you. This comes on when the outside temp is under 5 degrees Not as bad as the WTF heart stopping beep you get when your low on fuel.
Just a warning to let you know that it cold out side (more dense air, more peformance). Really it mean it could freeze outside so drive safely. Look at the climate control bet it has the same "turbine fan" symbol.
Multifunction display does something like: time ---> temp outside ---> miles done ---> miles left in tank ---> mpg ----> avg. mpg ---> driving time ---> avg. mph
hahah yes its so loud, i sometimes find ill drive a bit and it goes off, then ill drive a bit more and it will come on ! prob hills or something so i fget bleeped twice some days, doesnt help when your crawling in to your car to go to work after a night on the pop. ( fully sober of course )
The temp warning won't beep unless you're driving when the temperature drops below 4 degress.
If you start up at 4 or under, then it will flash a warning but no beep.
:lol: Turbo sign - PMSL! ;)
I'm blind not deaf! Fan, snow flake, whatever but definitely no beep!
Thanks for that peeps, I can rest now knowing that it's just dangerous outside, and there is nothing wrong with the car.
:happy: I know exactly what you mean. Passangers wonder what is going on.
i thought it could of been a snow flake signal for low temperature thats why i asked if it bleeped when it happend but i thought what are the chances of it being 2.0 'c all the times its happened :think: oh well at least you can rest your mind!
how didnt you find the "TURBO" icon in the manual :confused:
