b21playa
oil burner
Jan 10, 2005
544
Birmingham
hi all
a friend of mine said to me he is able to get the stuff to read the skc pin's for the above.
hopefully should have the stuff here within a week or so
is there anyone in birmingham who has the new immo unit and has a 4-digit skc code so i can test to see if it works?
alternatively is there a way to check if a skc is correct?
arent these codes generated by seat , they are tumbling codes and are only valid for 24hrs after issue
thats the 7-digit but some have been give 4-digit codes and work fine
i need someone with an immo3 and 4-digit code or somehow be able to test is a skc is correct (4digit)
well ive got the kit, ordered some transponders and will test on my car to see if i can program a key
it gives me a code, but when i try and login it says its incorrect, but i cant use the built in key program part without transponder
