There's a pressure drop on all IC's full stop
This is minimal on Forge's twin pass setup. but you have to make sacrifices if you don't want to chop much car up
'some' twin pass systems
It's minimal on the forge one (that I've measured)
Lesser designs have a bigger p-loss (and some single pass ones are worse still)
where are you looking to end powerwise?
i had the forge fmic which was fine whilst running at stage 1. no noticable difference cept power held better. fitted well and looked the business.
when i went bt the forge became the bottle neck and was swopped to an alloy designs fmic. that went in one and out the other. so yes alloy designs do one. i didnt fit it tho so couldnt say how easy. both coolers i guess rob a little pressure but nothing that i could feel.
The forge one is fine to flow to about 300bhp anyway... but we're not far off testing it with the GT28RS... copes no problem with revo stage 2, virtually maxxed out.
more high powerd lcs! excellent.
best of luck with it.
dpj should go bt. yours is the car that actually looks like it goes fast![]()
