I have had this problem in the past and put pipe cladding around the brace where it meets the airbox. Problem is now the rattle has come back. The airbox and cut straight through the foam padding. I think Its the reason for the noise at 2500 which i initialy blamed on the new milltek(opps). The airbox is that tight against the brace that it has cut through the padding. What are my options. Anyone else have this problem. Could it be sorted under warranty?. Basicaly what happens is for example in 2nd your gradually rise up the revs and when it gets to 2500 it gives a slight buz and then goes back to normal. The strutbrace is deffo rattling coz i get a noise at low revs 2.
washers
washers
