ko3s hybrid
gazjones
im looking at buying a blown ko3s and send it off to be rebuilt with ko4 internals. so should put out about 260 bhp. will the current maf i have need replacing or should it be ok upto 260bhp. also what is the limit on the injectors i have? ive spoke to revo and i can run the hybrid on my stage two map just turning setting down a slight bit.
where would the best place be for the turbo to be sent for the hybrid process, turbodynamics owen aet?
your thoughs and comments welcome
gaz
gazjones
it wil be like the jbs04 i belive and should be good for about 260bhp on my stage two revo. then could get it mapped latter on if i want even more power out of it
gazjones
dario from croatia has got the turbo done for around 400 quid ill ring few places up and see what they say
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Been having a look at some american sites with the exchange rate being strong atm this could be a cheaper option.
Looking for a k03s housing (milled out?) with k04 turbine (clipped?) or something along those lines.
That what you were thinking gazjones or something different?
gazjones
yep that sort of thing you got a link to any of these sites?
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Looked in a few UK places aswell.
AET page but no info on any turbos or prices so need to call- http://www.aetturbosonline.com/catalog/index.php/cPath/98_101
Obviously these guys could do it but again need to call for specs and prices- http://www.turbodynamics.co.uk/index.html
Now to the US these guys had good feedback from some forums and can do what we want but not sure 100% on price and actual specs- http://www.gpopshop.com/index.html
I also found these posts on other forums about the hybrid k03s but on other vags like s4 etc. Some good info that could be helpful and with pics!
http://audizine.com/forum/showthread.php?t=38062
http://rs246.com/index.php?name=PNphpBB2&file=printview&t=47837&start=15
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
E05 was early development and unreliable from what I have read and heard so this would be different as their is now a wealth of knowledge about what can be done and with the latter made turbos although they go by the same specs etc they have been slightly changed by Borg Warner to give better reliability amongst other things.
gazjones
cheers for that just over 300 quid for a ko3 hybrid. will this fit mine though as ive got ko3s and oiol lines ae different arnt they or water lines i not sure which
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Thats from the US site yeah?
This is where it becomes difficult as it seems some places dont believe in such a thing as k03s.
I have a mk3 ibiza cupra with normal k03 turbo. I dont know the physical differences between k03 and k03s with regards to internal housing and turbine size etc so need to know this really.
We need some of the SCN knowledge now to help figure this bit out!
gazjones
not sure if that is just an early ko4 as stated in early post. but thanks for the link got more things to look at now :D
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Kind of but I was under the impression that the k04-001 was not v.reliable aswell and that better gains could be had from a k03s hybrid which is different but I may be wrong.
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
all i know is k03s has 8 fins on the turbine, k03 has 12 fins! cant you just give them the turbo code? they may have the same turbo, but have a different name for it?
gazjones
thats what i thought. want a ko3s housing so its a straight swap but better internals like on the rs4 forum
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Exactly what I want k03s housing but with k04 internals so should hopefully have 240bhp minimum real power from a simple turbo change that has not cost more than £400 really without mapping. Heres hoping!
gazjones
im hoping for around 260 bhp from same sort of setup using my existing stage two map. the second audi link is so confusing as they are going on about the twin turbo ko3's that mount different to 1.8t transvers ko3's and 3s's
