Just done some logs...what do you think?
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Right then just attempted some runs in the Cupra..
Forge 007, Forge TIP, N249 bypass, P torque Stage 1 map, Milltek cat back exhaust....Piper X Cone Filter and about 6 months ago a new MAF!
Here are the results... on the second run i did have to lift off for a corner slightly so thats why it dips about 5k.......
Run1:
Group A: '003
RPM Mass Flow Load Ign. Timing
TIME
STAMP /min g/s % °ATDC
0.89 1040 16.17 97.3 4.5
2.19 1120 18.92 100 0.8
3.5 1240 20.42 100 3.8
4.7 1360 24.92 100 3
5.88 1480 29.67 100 2.3
7.08 1600 34.11 100 0.8
8.28 1800 40.5 100 3
9.48 2000 48.47 100 4.5
10.89 2280 63.64 100 3.8
12.09 2520 75.39 100 6
13.38 2840 81.28 100 7.5
14.68 3120 94.83 100 9
15.99 3400 102.58 100 10.5
17.19 3680 113.36 100 10.5
18.39 3920 120.42 100 12
19.59 4160 131.53 100 11.3
20.79 4400 138.58 100 12.8
22.2 4680 146.28 100 12
23.4 4840 152.36 100 12.8
24.6 5040 154.47 100 12.8
25.78 5160 4.36 10.2 3.8
27.09 4640 8.89 6.7 14.3
36.77 3480 6.58 5.1 13.5
37.97 3360 6.58 5.1 13.5
39.17 3240 6.31 4.7 13.5
Group B: '115
RPM Load Absolute Pres. Absolute Pres.
TIME
STAMP /min % mbar mbar
1.29 1040 80.5 1330 1090
2.59 1160 84.2 1480 1140
3.9 1280 88 1640 1180
5.08 1400 91 1850 1220
6.28 1520 99.2 2020 1280
7.48 1680 107.5 2090 1400
8.68 1840 117.3 2120 1540
9.88 2080 129.3 2140 1700
11.29 2360 148.1 2150 1960
12.49 2640 156.4 2140 2050
13.78 2920 151.9 2120 1990
15.08 3200 157.9 2110 2020
16.39 3480 157.1 2080 2010
17.59 3760 159.4 2090 2050
18.79 4000 159.4 2080 2050
19.98 4240 165.4 2090 2090
21.19 4480 163.2 2080 2040
22.6 4720 163.9 2040 2020
23.8 4920 163.2 2000 2000
24.98 5040 159.4 1990 1980
26.18 4920 9 990 1200
27.69 4480 9.8 1150 515.13
37.17 3440 9.8 990 1020
38.37 3320 9.8 990 1020
39.57 3200 9.8 990 1020
Group C: '118
RPM Temperature Load Absolute Pres.
TIME
STAMP /min °C % mbar
0.49 1000 32 95.3 1050
1.69 1080 31 95.3 1110
3.1 1200 31 95.3 1150
4.3 1320 30 95.3 1190
5.48 1440 30 95.3 1240
6.68 1600 30 95.3 1310
7.88 1720 31 95.3 1440
9.08 1920 31 95.3 1590
10.39 2160 32 95.3 1790
11.69 2440 33 73.3 2010
12.98 2720 34 70.2 2020
14.18 3000 36 69.8 1970
15.59 3320 37 72.5 2020
16.79 3560 39 73.7 2010
17.99 3840 42 75.3 2050
19.19 4080 45 78 2080
20.39 4320 48 78 2070
21.69 4560 51 80 2040
23 4800 54 81.6 2020
24.2 4960 56 82.7 1970
25.38 5080 57 84.7 1980
26.68 4760 50 0 1080
37.57 3400 42 0 1020
38.77 3280 41 0 1020
40.08 3160 40 0 1020
RUN 2:
Group A: '003
TIME
0 1360 23.64 100 3.8
1.41 1520 29.53 100 3
2.61 1720 36.08 100 3
3.81 1920 44.86 100 3.8
4.99 2160 57.11 100 5.3
6.21 2440 69.94 100 4.5
7.39 2720 80.42 100 6
8.59 3040 87.28 99.6 9
9.81 3320 99.33 100 9.8
11.01 3600 107.36 100 11.3
12.21 3880 116.11 100 11.3
13.5 4160 131.69 100 11.3
14.7 4400 136.22 100 12.8
15.9 4640 144.64 100 12
17.1 4840 139.22 66.3 12
18.3 4920 116.25 100 12
19.5 4800 7 5.5 14.3
20.91 4960 152.81 100 12.8
22.11 5240 159.28 100 12
23.31 5440 161.17 100 11.3
24.51 5600 159.89 100 9
25.69 5720 161.03 100 12
26.89 5800 161.56 100 11.3
28.09 5720 5.42 5.1 22.5
29.29 5480 9.56 7.5 15.8
30.49 5120 9.19 7.1 15
31.69 4720 8.47 6.3 14.3
32.99 4360 7.25 5.9 13.5
34.38 4040 7.17 5.5 13.5
35.58 3760 6.64 5.1 13.5
36.78 3440 6.19 4.7 13.5
Group B: '115
TIME
0.4 1400 88 1850 1200
1.81 1600 100.8 2070 1300
3.01 1760 111.3 2140 1450
4.21 2000 121.8 2150 1620
5.39 2240 139.8 2170 1860
6.61 2560 149.6 2160 2000
7.79 2840 150.4 2140 1990
8.99 3120 154.1 2120 2000
10.21 3400 156.4 2110 2020
11.41 3680 159.4 2090 2040
12.61 3920 159.4 2100 2060
13.9 4240 166.2 2090 2130
15.1 4480 163.2 2090 2060
16.3 4680 164.7 2050 2050
17.5 4800 64.7 1380 1370
18.7 4920 40.6 980 1680
20 4760 9 980 1050
21.31 5040 160.2 2010 1950
22.51 5320 156.4 1980 1950
23.71 5520 151.9 1950 1930
24.89 5640 148.9 1910 1920
26.09 5760 147.4 1880 1880
27.29 5840 142.9 1140 1890
28.49 5640 7.5 990 1070
29.69 5400 9 990 1050
30.89 4960 9 990 1050
32.09 4520 9 990 1040
33.4 4240 9 990 1040
34.78 4000 9 990 1040
35.98 3680 9 990 1030
37.18 3360 9 990 1030
Group C: '118
TIME
0.9 1480 36 95.3 1230
2.21 1640 36 95.3 1350
3.41 1840 36 95.3 1500
4.61 2080 36 95.3 1690
5.79 2360 36 76.1 1950
6.99 2640 37 69 2010
8.19 2920 38 71 1970
9.39 3240 39 72.9 2010
10.59 3480 42 74.1 2030
11.81 3760 45 73.7 2050
13.1 4040 48 76.1 2070
14.3 4320 50 78.8 2110
15.5 4560 53 80.4 2060
16.7 4760 55 80.4 2040
17.9 4880 54 59.2 1630
19.1 4880 51 0 1180
20.4 4800 49 95.3 960
21.71 5160 52 94.9 1980
22.91 5400 54 95.3 1930
24.11 5560 57 93.7 1900
25.29 5680 60 92.9 1920
26.49 5800 63 92.5 1880
27.69 5800 62 0 1370
28.89 5560 56 0 1060
30.09 5240 54 0 1050
31.29 4840 51 0 1050
32.49 4440 50 0 1040
33.9 4160 49 0 1040
35.18 3880 48 0 1040
36.38 3560 48 0 1030
37.58 3280 47 0 1020
The temp outside was about 22 oC
So what kind of power am i giving out...is my N75 knacered :)
etc etc......
Thanks for looking and commenting!
rich
Nov 2, 2004
9,334
South Wales
Can you put CODE around them so we can read them a bit better pleeeease. :D
Other than that looks ok, meets the requested well, duty cycle looks spot on 95.3 shut to build boost then drops to low 70's then back up as the turbo works harder. MAF looks spot on as well, 161g.s peak.#
No FMIC? 63 degrees intake temps is gettin mighty hot.
Any timing logs?
Funkyfin2000
Oct 6, 2005
2,477
CODE?
Hmmm well heres the link to the CSV files might make it a bit easier..
thanks Phil for the info....
Intake Temps are hot then? What will that effect? Heat soak? just slow me down presumably....maybe £800 for a forge FMIC maybe the next thing to do....
http://www.funkyfin2000.f2s.com/log1.csv
http://www.funkyfin2000.f2s.com/log2.csv
What block do i need for timing and what would you get from that?
Also what kind of bhp am i getting or psi?
Forbez
Huge Member!
Feb 11, 2004
5,877
S.Wales
Visit site
Code:
Run1:
Group A:	'003
TIME
Group B:	'115
TIME
Group C:	'118
TIME
RUN 2:
Group A:	'003
TIME
Group B:	'115
TIME
20	4760	9	980	1050
Group C:	'118
TIME
19.1	4880	51	0	1180
33.9	4160	49	0	1040
etc etc......
rich
Edited
Nov 2, 2004
9,334
South Wales
020 is timing.
You dont get much of a boost spike like most of us get, it seems to be runnig what its requesting. Personally i like the boost spike as it gives you a kick in the arse, which i found better with an N75J.
You spike at about 15psi.
Funkyfin2000
Oct 6, 2005
2,477
hmmmm its not running as high boost as i expected then.... some of the stage 1 revo go to 19-20psi.......
so prob about 190bhp then or so???
thanks for editing that, looks good....
what will the timing show?
Funkyfin2000
Oct 6, 2005
2,477
time for FMIC....milltek sport cat........(presume still passes MOT with this)
and then KO3s and a new map!
ouch sounds expensive when im trying to buy a Cupra R Leon at the same time and pay for a wedding! :D
