Status
Not open for further replies.
Ollie, i got 16.2mm from the end of the rod to the face of the first nut with my digital calipers :D
Right thanks for that. I'll check mine now then. Im not conviced all actuator rods are the same length though. Be better measuring from the actuator body itself to the top nut i think, that way you get a more accurate reading and the rod length should'nt mater. :D
I'll do that now for you ollie.
I would keep winding the nut in tbh, just keep checking the boost levels so you dont throw it into limp mode.
Got lemmiwinks working properly now. :D
Ok cheers! You reckon i should keep winding it in? What sort of peak boost do you reckon is safe on a K03s then? Ive now done 4 turns (67.6mm from actuator to top nut) and seeing a peak of 2410mbar. Thats with settings at B8T8.
Its gona take me atleast 4 turns to see that much boost i think. Im only seeing wastegate in the mid 80's high up the rev range. Dont spose you know how far up the rod your actuator is set do you Daz? (from actuator to top bolt).
Im not quite sure how much further i should turn it.
Well im up to 16 threads now which isn't exactly excessive. Do i just need make sure the wastegate duty doesnt rise to 100% for too long then? Whats a sensible amount to stop at?
95-100% jammed shut to build boost which generally causes a boost spike. Your WG % should then fall to around 70% then climb back up as the turbo works harder to meet the requested furter up the rev range.
Keep winding it in i reckon and see how it feels and change it to boost 9.
Keep an eye on block 020 as well, the harder the turbo works the hotter the air will be so you might see an increase in CF's.
When i get the car back if i get the same logs as i was gettin previously i'll run HB9T9 and add some degrees with lemmiwinks along with some actuator cranking.
Right up to 17 threads set at B8T8 i got the following result. What you reckon lads?
Code:
Group A:	'115				Group B:	'114
	RPM	Load	Absolute Pres.	Absolute Pres.		Load	Load	Load	Load
TIME					TIME
STAMP	 /min	%	 mbar	 mbar	STAMP	%	%	%	%
0.59	1880	90.2	1790	1250	0.29	139.1	132.8	86.5	100
1.19	2000	99.2	2010	1370	0.89	152.6	146.3	93.2	100
1.79	2160	116.5	2050	1520	1.49	164.7	158.2	106.8	100
2.39	2320	133.1	2100	1730	2.09	169.9	162.7	125.6	100
2.99	2520	148.1	2150	1960	2.69	175.2	168.7	140.6	100
3.59	2760	163.2	2160	2170	3.29	178.9	171.6	156.4	91.4
4.19	3080	180.5	2170	2390	3.89	182	174.6	172.9	87.1
4.8	3280	183.5	2180	2420	4.49	184.2	177.6	185	83.1
5.39	3600	182.7	2170	2400	5.1	186.5	179.1	186.5	82.7
6	3840	181.2	2170	2380	5.69	187.2	179.1	182	82
6.59	4080	179.7	2180	2290	6.29	187.2	179.1	179.7	81.6
7.2	4320	175.9	2150	2240	6.9	186.5	179.1	177.4	80.4
7.79	4560	173.7	2130	2200	7.49	185.7	179.1	173.7	79.6
8.4	4800	171.4	2100	2140	8.1	185	177.6	172.2	78
8.99	5000	167.7	2080	2110	8.7	184.2	176.1	169.2	77.3
9.6	5240	163.2	2040	2040	9.3	181.2	173.1	166.9	76.1
10.2	5360	157.9	2020	2030	9.9	177.4	170.1	161.7	75.3
10.8	5560	153.4	2000	1990	10.5	175.2	167.2	155.6	74.5
11.4	5680	149.6	1970	1960	11.1	171.4	164.2	151.1	73.7
12	5840	146.6	1960	1900	11.7	167.7	159.7	146.6	73.3
020 118?
I'll try find a plot of mine.
Code:
6K0 906 032 AA 		1.8L 20VT EU3       0002
	Group A:	'118
		RPM	Temperature	Load	Absolute Pres.
	TIME
MARKER	STAMP	 /min	°C	%	 mbar
	0.01	2440	20	0	1090
	0.42	2480	20	0	1090
	0.91	2520	20	79.6	1130
	1.31	2600	21	100	1530
	1.71	2680	21	100	1900
	2.11	2800	21	86.7	2220
	2.51	2960	21	82.7	2470
	2.91	3120	21	82.4	2530
	3.31	3320	21	81.6	2540
	3.71	3440	21	80.8	2540
	4.11	3600	22	79.6	2540
	4.49	3760	23	78.4	2540
	4.89	3920	23	76.9	2510
	5.31	4080	24	75.3	2470
	5.71	4240	24	73.3	2410
	6.21	4400	24	70.2	2320
	6.61	4520	25	68.6	2270
	7.12	4680	26	66.7	2210
	7.52	4800	26	65.9	2160
	7.92	4920	27	65.5	2120
	8.32	5000	27	65.1	2110
	8.72	5120	27	65.5	2070
	9.12	5200	28	65.9	2040
	9.52	5280	29	66.3	2030
	9.92	5400	29	66.3	2020
	10.32	5480	30	66.7	1990
	10.72	5560	30	67.1	1970
	11.12	5640	30	68.2	1950
	11.5	5720	31	74.5	1930
And with Boost 9 timing 8......
Wastegate working harder but boost seems to be peaking lower :confused:
I havent seen any timing pull in block 020 even with boost set to 9, but the cooler temperatures tonight tonight might be helping.
Code:
'114				Group B:	'115
Load	Load	Load	Load		RPM	Load	Absolute Pres.	Absolute Pres.
				TIME
%	%	%	%	STAMP	 /min	%	 mbar	 mbar
169.9	161.2	103	100	0.35	2040	92.5	2090	1240
176.7	167.2	121.1	100	0.95	2280	112.8	2130	1450
182	173.1	137.6	100	1.55	2520	130.1	2210	1690
185	176.1	156.4	99.2	2.15	2760	145.1	2220	1930
187.2	179.1	175.2	87.8	2.75	3080	167.7	2230	2190
190.2	182.1	175.9	86.3	3.35	3360	177.4	2230	2330
190.2	182.1	175.2	85.5	3.94	3680	174.4	2210	2310
190.2	182.1	174.4	85.1	4.55	4040	173.7	2210	2280
190.2	182.1	171.4	84.7	5.14	4320	172.9	2180	2230
190.2	182.1	169.9	84.7	5.75	4560	169.2	2160	2160
189.5	180.6	165.4	86.3	6.35	4840	168.4	2140	2110
184.2	176.1	160.2	96.9	6.95	5120	163.9	2130	2050
179.7	171.6	154.1	98.4	7.55	5320	156.4	2100	2010
175.9	167.2	147.4	100	8.15	5560	148.9	2060	1960
171.4	164.2	144.4	100	8.75	5720	145.1	2040	1890
168.4	159.7	141.4	100	9.35	5920	142.9	2010	1850
Wastegate Duty is in the 4th column of block 114 above Daz. Below is a log of the MAF and Timing pull with settings at B9T8
Code:
Group A:	'020				Group B:	'002
	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Inj. On Time	Mass Flow
TIME					TIME
STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 ms	 g/s
0.3	0	0	0	0	0.6	2040	100	11.89	42.89
0.9	0	0	0	0	1.2	2200	118.8	13.94	52.97
1.5	0	0	0	0	1.79	2400	133.8	16.4	66.11
2.09	0	0	0	0	2.39	2600	149.6	18.86	78.67
2.7	0	0	0	0	2.99	2880	164.7	20.91	92.36
3.29	0	0	0	0	3.59	3120	178.9	22.55	106.78
3.89	0	0	0	0	4.19	3400	183.5	23.37	124.14
4.49	0	0	0	0	4.79	3680	178.2	22.55	124.11
5.1	0	0	0	0	5.39	3920	178.2	22.96	132.39
5.7	0	0	0	0	6	4200	176.7	22.96	138.19
6.3	0	0	0	0	6.6	4440	172.9	22.55	148.36
6.9	0	0	0	0	7.2	4640	172.2	22.14	154.78
7.49	0	0	0	0	7.8	4880	170.7	22.14	159.19
8.1	0	0	0	0	8.4	5040	167.7	21.73	160.58
8.7	0	0	0	0	9	5240	161.7	20.91	163.08
9.3	0	0	0	0	9.6	5400	156.4	20.5	165
9.9	0	0	0	0	10.2	5560	150.4	19.68	158.94
10.5	0	0	0	0	10.8	5720	148.1	19.27	161.17
11.1	0	0	0	0	11.4	5800	145.9	18.86	160.92
11.7	0	0	0	0	12	5920	143.6	18.86	163.19
12.3	0	0	0	0	12.6	6120	141.4	18.45	164.03
12.9	0	0	0	0	13.2	6120	139.8	18.04	164.33
Status
