Leon ATP GTRS Eliminator install
RobDon
Pro Detailer
Well mine now makes 1.4 BAR at only 56% boost duty cycle ... so yeah, more is there! ;) Previously with the Forge hose it took 75% duty to make 1.3 BAR - big difference with the big inlet! I hope to get it on the dyno soon to see what it's making just now.
ChriS3
Why has it only been mapped to 64% duty cycle? Restriction from the standard mani causing problems with high exhaust temps and CFs?
Or just a conservative level of tune?
Yeah, as Rob said, its 64% wastegate duty cycle with the AVC-R. The turbo will run 350bhp at 72% but I'm still running standard internals - better safe than sorry.
ChriS3
I was admiring your car when mine was in getting the turbo fitted, nice motor :thumbup:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Nope, away on business for 2 weekends, and just working bloody hard elsewhere
only needs map, driveshaft bolting on anyway.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Hope you don't mind if I post in here rather than starting a new thread.
The GT28RS Eliminator kit I've acquired includes an ATP big bore inlet. :funk: It isn't here yet.
If the turbo is clocked, it won't affect the position of the inlet, will it?
Is the following the way forward? (Pics borrowed from the vortex thread)
and
(with altered bracket on top)
Also, does anyone know if Kev from Revo is away this week?
myk3
Newbie
Dec 16, 2005
304
nope wont effect the comp inlet if you clock it, you shoudlnt need to clock it though. and yes if you go the 5 speed tranny then you will need to grind that down, its simple with the use of an angle grinder
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
but what does foul is the inlet on the gearbox/block depending... where the thing bolts on - the centre remains exactly that, but the locating bolts move
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Is that a 5 speed in the pics, whoever referenced it said it was a 6 speed. :confused:
I'm back now, albeit with a slight hangover...
just sent you a PM. If you want I'm on email all week!
Cheers Kev, reply sent. :)
It was a daft question really. Mine will end up clocked at the same angle as Jonah's.
myk3
Newbie
Dec 16, 2005
304
is there an update with this install or is it still wating for the drive shaft bolting up? then mapping?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
So here's mine at the moment.
With the spare lug that's standing up on the diff housing off, I reckon the ATP big bore inlet would go on. The question is, will it be in the right position to meet the Compressor inlet, or are the gear linkage brackets in a different position on the 5speed?
