N249 bpass and Over BOosting
ian_cupra
might be fairly similar, dunno to be honest, supposed to hold boost higher than normal
ian_cupra
no not at all, mine is fine, not done it since putting this on, and boosts to 17/18 and holds it, even on k03
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
will do mate...
what did you do for the clips for the tubing to the n75 at the mo i have 1 jubliee on the bit going to the TIP and the other 2 have seat metal clips (i don't think these can be reused?)
did u just use 2 jubilees?
u got any pics of urs?
ian_cupra
think you get get some new clips with it, not sure, cant remember exactly.
not got any close up pics of the n75
Jun 29, 2001
536
Surrey
Race valve is a H type valve (as opposed to J, F or C varient).
I have one at home. Very aggressive on initial spool up. Boost is at least a couple of psi higher. Doesn't seem to hold boost as long as the F type, though, which was OE on mine (older ones came with the C type). Limp mode was a regular occurence on the H valve, so I went back to the F. The F feels much smoother IMO. Some cars will work fine with the H type, some won't. No rhyme or reason to it I'm afraid.
Nov 2, 2004
9,334
South Wales
Your getting overboost and want to try a race valve? I dont get this, they normally show higher boost spikes and higher boost up top so theres more chance your gonna see gimp mode imo.
ian_cupra
thought the reason you get over boost was because the actual boost is higher than the requested boost??
