I managed to get all the fluid lines connected up.
Still to do:
Fill fluids
Fit injectors
refit ecu.
I'm a bit wet and demoralised though - the induction side doesn't quite fit with the turbo in place.
The red hose that connects to the compressor inlet keeps slipping off the oval big bore - looking at it, it's been cut down. It's actually a reducer hose. If it was an inch longer, I'm pretty confident it would work. I'll investigate what I can get tomorrow.
Still to do:
Fill fluids
Fit injectors
refit ecu.
over a weekend between family comitments. If it went too easy, you wouldn't appreciate it as much.
Thank you!
