How come nobody found out about this ages ago that the porsche calipers just fit straight on with no other modification needed? seems abit too good to be true, now off the the scrap yards we all go in search of some porsche calipers lol. exactly what model doe they come off? What type of clearance issue do they have as they look massive? ie what wheels will they fit behind, standard cupra 16" or wheels that suite the likes of wilwood or brembo.
nothing new here.
nothing special about "porsche" calipers either... aside from badge snobbery.
they're brembos
same clearance issues as regular GT junior calipers.
not a hope of them fitting behind stock cupra 16's imho
badge snobbery or not, its a pretty dam coo, set up, if your into the german styling i.e. porsche wheels and detailing like some of the VW lot, then personaly i think its a great mod.
some really helpful info there guys thanks alot.;)
porsche calipers are made by brembo, think the clearance issues are even worse for the porsche calipers, being 5mm worse than the brembo ones, also the fittings arent the same from memory
Not my cup of T
each to their own of course.
their performance will be identical.
thats very true, but if your into oem/oe modding then these would be the only choice to not having to go after market i suppose though.:confused:
I have done this conversion before on my cupra.
Sadly crashed the car so someone out ther has probably brought them from the scrappy. The cars for sale on ebay being broken for spares in colchester, may still have the brakes on it.
I used boxter front calipers, purchased neuspeed conversion brackets and hoses for golf and custom made a 4mm spacer, used alcon 315mmx28mm discs, and sent hub away and had custom bells made by BG developments. Used 17" team dynamics pro race 1 alloys with standard offset and had loads of clearance from caliper.
An easy conversion to do, once you have done the hard stuff ! have part numbers for discs, design number for the hats, pm me for all the part numbers and this set up will fit straight.
how do you paste pictures ? would stick some up of the setup if i knew how !
hooch did you buy the setup from breakers? got all the receipts for the bits if you want them for your records. had only done about 500 miles with them, hit kerb at about 60mph, so would check for damage before fitting ! p.s got your old k04 kit !
Hooch - I would check the brakes if your using them they got spanked f'kin hard when i crashed hence the reason they were left on the car, got some photos of them hanging off my motor when i stacked it - not to healthy, if someone tells me how I will post the pictures
Nick_Barnes - Black Cupra R you might recognise it?! Its just having a few more horses extracted at the moment will let you know the figures.
i will post pics of brakes got some good ones i havent posted!
reciepts would be good!
brakes are fine
what you doing to k04!?
very very small world!!
HoocH
get an account with , www.photobucket.com , then upload them to your photobucket , paste the code after they been uploaded , and paste it in here
Managed to upload some pictures:
Look good now though Hooch im glad they've gone to someone who will appreciate them, PM me your details and I will send you the receipts and stuff
they look alot worse in pics compared to when i got them
only had a few marks!
whats happenin to k04 then?
gagin to know
