A place for a Turbo Boost gauge
Kogi
Newbie
May 3, 2006
60
Thanks Kogi have sent pic to you.
Here you go !
Kogi
Newbie
May 3, 2006
60
Nice idea !!
Few remarks:
- You dont smoke :lol:
- Did you make it by yrself ?
- 12V power plug access is no longer available, right ?
- OBDII plug ?! how can I get one to connect VAG-COM utility ?
Looks wonderful !!!
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
;)thanks,
no not made by me i got the mounting from a place around the corner (£3.00) they also do one to take three gauges, which might fit.
yes the 12v is still available as the ashtray still opens and the OBDII is still accessible as it is screwed to the underside of the ashtray and when it is removed you can not see the screw holes.:funk:
Kogi
Newbie
May 3, 2006
60
Good idea .. cup holder , right ?
I was thinking to rebuild the whole panel and place 3 gauges on it (boost, oil and something else ) ... However it will require to relocate the (!) and rear window heating buttons, maybe put it under the arm-break ....
Anyone either thought or did it before ?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Well it was easy to remov ethe cup holder, but the rest look like a mission, i wanted toi put 2 more gauges there or perphaps fit on board diagnostic device there. but i dont want to tamper with rear screen heater as i asume it draws alot of power and i dont want to rewire it any were. hazard should be fine but i cant be asked with the hassle.
Took hours sorting the gauge out, i had it 1st stuk on the window glass witha pod but the double sided tape keeps coming off when it gets stuff in the car!
