T. Spark
Any updates Mr Spark ?
There is indeed actually, the turbo has started to not kick in till later and later, and now seems stuck at 3k instead of 2k. So everything that should happen between 1.5k to 2.5k is happening at 2.5k to 3.5k this has happened before and ended up being a sticking turbo vain from what I can remember, but last time I wasnt down on power, just the power didnt kick in till later? weird!
Anyway, after driving it a far few miles the turbo last night started spooling at its usual RPM and everything seemed fine on the car, minus its down on power by 20bhp and the gearbox is still as stiff as a 17 year old lad looking at the top shelf in the corner shop.
Turbo is knackered FACT. So even tho its in warrenty, im thinking of just uprating the damn thing, that should sort out the loss of power and rpm problem.
Gearbox - No idea still, gunna try the oil change see if that helps
Judder - Again still no idea, clutch bites fine, would the flywheel be knackered but the clutch be perfect?
