if you look under you'r bonnet, youll notice pins sticking up off the strut, you'll have to cut those off and file them flush with the top of the strut
which is what i did, then you'll have to remove the washer jet water bottle and cut its holding clamp to suit,
oh, and drill you'r struts, get under the weather proof plastic on the arch and nut and bolt the fooker ;)
http://www.larkspeed.com/
Seat Ibiza 1994-1999 £64.50
^^ its that one on the list
under suspension components
is where i got mine, good luck pal
Fits fine :) got one on mine.
Don't think I even shaved anything off. Went straight on :)
