Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
As above,
Will the TCS/ESP be more sensitive that a differential? Therefore cutting the power before the diff does its work.
If so can this safety features be turned off totally within the mapping process to allow the diff to do its work
Did you find it was fekin with your diff control?
Did you try just pulling the fuse for the ESP/TCS?
If so did it throw a wobbly and give you fault codes?
ibiza mod is simply to switch it into its switched off position as normal.
if you have a switch for turning it off, press it... thats as off as you are likely to get it.
diff will be allowed to work far better then power wise.
not esp cars tho sfaik
switch turns of asr but not edl, and if you have esp, you cannot dissable it completely with the switch, it just increases it's threshold.
on a leon if you have asr open the abs controller with vag com and code it 0004097 rather than the standard 0021505
This disables asr and edl but leaves abs active. This may also work with later esp enabled abs controllers, but |'ve not tested it.
Cheers Wilko
