ntrueman
31
Well, I have a '97 GTi Cupra Sport 8v and was playing around with it the other day trying to figure out my average MPG around town. It worked out about 22.1MPG now I know the computer gives you your average MPG but is it possible for it to display your "LIVE" as it were MPG?
yeh lol what he said ...try this for fun, reset it when ur in 5th gear doing about 54ish mph ...mine went to 80mpg ...then all the way down.
Believe it or not there is a way to get it except i cant remember lol. There was a post a while ago where you were able to get extra readings off your trip computer and one of these readings was the 'live' mpg. I think it also gave you a digital rev reading or speedo reading but not sure about those.
You had to push the button to one side and turn the key or something like that.
Im sure someone will come that remembers/knows what im talking about.
Yeah I think there is a way to get the info up. Well there is a "secret area" to the service computer. I remember reading it on a polo forum WAYYYY before I started driving. Loadsa useless info in there that I thought would be soo cool to have on my car if I had one with a trip computer!
Ive tried searching but i think it was posted on another ex seat forum *cough cough*
Somne ones got to know. Otherwise im going to start experimenting lol.
Quick search reveals :D
Hold the button in, turn your ignition on, off and on again
position 1:
Default: Engine code
1: Land code
2: Speedometer
3: Upper rev limitter
4: Lower rev limitter
5: Decelaration fuel pressure
6: Display test
MFA switch on position 2:
Default: Test programm of programmed bytes (checksum)
1: Intake Vacuum
2: Digital rev counter
3: Fuel usage (like normal)
4: Signal from speedo sensor
5: Oil temperature (like default)
6: Ambient temperature (like default)
Right just tried it and it disables the top 3 features so that you can only use the MPG, Oil Temp and Outside Temp. This is the same on MFA 1 & MFA 2
Mines a 1997 GTi 16v. Any ideas?
Mine does exactly the same, once into the extended MFA options it disables the top three options. But it does show me the "live" MPG and thats great! Thanks for the help guys!
Its all well and good that it shows the "live mpg" but i want all this!:(:
position 1:
1: Land code
2: Speedometer
6: Display test
1: Intake Vacuum
Just tried it and mine does exactly the same on a 99 Cupra 8V. I wanna get all those options :cry:
