DPJ, inside the box, is theere a joint where the fuel line meet? i somtims get sniff of petrol when starting, checked the the injectoors, fuel filte.
If i wanted to check that box, how do i remove the cover?
No joints below. The forward pipe is the breather. I really wouldn't worry unless you get a petrol smell when you lift the bonnet after the engine has been running. The fuel is under pressure. If there's a leak, you'd know about it.
