h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
right,
im about to put a big port head on mine as my stem seals are shot so its a good time to upgrade.
what will need changing on engine? if anything?
am i right in believing map will need adjusting
ta very much :)
good point phil...didnt even think of that! cheers
i think it will fit just its not big port!?
can anyone confirm it wont need mapping?
i no i gota get my car sorted 1st but dont wona remap it before i fit head if it needs mapping to suit
how much is the 007 with r32 TB?
007 being the proven best flowing big port mani with r32 throttle body
cheapest quote i got for t'body is 175+
007 mani is approx 499
This might sound like a pathetic question, but whats the build quality in the 007 like? As i'm after a bit of engine bay eye candy i want something that not only works well but looks good.
Gay i know. lol.
Neh shouldn't need mapping but for max benifit you should.
Just got my car up and running there with small port head ported and polished. Port sizes comparable to a std largeport.
Everything seems fine after 42 miles touch wood :)
You'll need a full head gasket set.
cams would be similar spec anyways not a great deal difference, not like lumpy rally cams.
But if youve got a large port head on it then more air will be entering as well as the tb your getting so more air = more fuel reqd so to get it running correctly without runing too lean you should get it mapped bear in mind the the air mass drawn will be greater.
is the ex port and int been enlarged???
