Meatball
I've got a problem with my car at the moment.
I've had some problems lately with ignition, and have changed:
plugs
plug leads
dizzy cap + rotor arm
coil
replaced a short fuel hose
also cleaned up the throttle body.
It is running almost perfectly, but it occasionally just cuts out,
usually around idle.
it won't restart straight away but seems to go again after leaving it 10 - 15 seconds and a couple twists of the key, and runs smoothly. Does anyone have any suggestions for this? Could it be fuel pump/filter? I've got a new fuel filter that is still to be fitted.
Cheers.
plugs
plug leads
coil
usually around idle.it won't restart straight away but seems to go again after leaving it 10 - 15 seconds and a couple twists of the key, and runs smoothly. Does anyone have any suggestions for this? Could it be fuel pump/filter? I've got a new fuel filter that is still to be fitted.
Cheers.
