pm me your address mrk and i will send it to you
Glynn
you have pm
Glynn
Mine is from a leon cupra 150pd
part number pa666f35
Glynn
thats an odd part number, not in the usual VAG format ie 1H0 906 627 A
Ibiza 110 sport N75/turbo control EPV/pressure converter:
Seat/Audi/Ford/Skoda/VW Part number = 1H0 906 627 A
Pierburg part Number = 7.21903.75.0
Which supercedes these earlier identical parts:
7.21903.15.0
7.21903.25.0
7.21903.25.1
7.21903.25.2
7.21903.25.5
ALH & ASV engines from chassis number 6K-X-400 000 to 6K-X-499 999 need part number:
OEM = 1J0 906 283A (98 AB 9E882 AA)
Pierburg = 7.02256.01.0
my mates dads merc had this problem tdi again it was the cat was blocked had a new cat on fine. but before it would nt go past 3 k revs but now its all good
You got any further with this? Mine (leon 110tdi) was playing up a few months ago so replaced the MAF sensor. Did an ecu reset and has been fine until last night. Went full throttle in 3rd and got up to just over 3krpm and felt as though had lost boost. Tried different gears but would struggle to get much higher than 3.5k rpm. Pulled over and switched off for a few mins and tried again, it drove spot on, no probs. Been ok today but its a bit worrying when your over taking that it may happen then!!
Is that this N75 thingee, previously talked about? Its the vaccum control for turbo wastegate is it? Located on bulk head?
