Key Not working
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
Well I now have the car but as usual when buying a car Im off to a flying start the central locking wont work on the car. It will work from inside with the button and Im sure there the same fuse. The key has worked once and never again.
I have changed the battery and tbh Im pretty stuck with any other ideas what to do. Will get vag com on it in a moment and see what faults the car has.
Other than that though the car is pretty much spot on.
CHR15B
2,567
9
Scotland
Run over it with VAG-COM and try the recode feature too (Search through the flip key thread).
When you press the button on the key - does the red LED come on, might just be a dead battery?
Glad you like the new car, and welcome to the dark side that is "TDI" :)
CHR15B
2,567
9
Scotland
I'm not any expert with this, but I guess something might be up with the sensor for the remote fobs ... no idea where it is though.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
my vag results they mean nothing to me though VAG-COM Version: Release 409.1-US
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
Controller: 038 906 019 HQ
Component: 1,9l R4 EDC 0000SG 1502
Coding: 00002
Shop #: WSC 06402
VSSZZZ6LZ2R011893 SEZ7Z0A1193827
1 Fault Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 6Q0 907 379 C
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 00000
No fault code found.
Address 08: Auto HVAC
Controller: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01272 - Positioning Motor for Central Flap (V70)
Address 09: Cent. Elect.
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 00140
Shop #: WSC 06402
2 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00907 - Intervention load Management
35-00 - -
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6L0 920 920 J
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 00442
Shop #: WSC 00000
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 06402
Address 44: Steering Assist
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00111
Shop #: WSC 06402
Address 46: Central Conv.
Controller: 6Q0 959 433 E
Component: 58 Komfortgerát 0001
Coding: 00065
Shop #: WSC 06402
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
End --------------------------------------------------------------------------------------------------
CHR15B
2,567
9
Scotland
I get the climatronic one - wouldn't worry about it.
The intermittent central locking one though - that might be related to the issue your having.
The battery & alternator ones could be caused by a loose connection or something drawing too much power from the battery.
Clear them all, then run a scan again this time next week and see what ones have come back... some random ones popping up every now and then isn't a major issue.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
fixed it I think, the lad who had the car before me had the wiring in the headunit the wrong way round. Once I swapped that over the cnetral locking started working :S
bizzaboy
That's a bit random! Headunit replacement = Near side central locking defective.
Good to hear that's sorted now though! Out of interest, where did you pickup your VAG.COM cable and software? Where does it connect into the car?
Cheers.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
connects under the driver side drawer (pull it out).
Got the vag cable of ebay and the software from rostech the official website
bizzaboy
Cheers Guinness, thats interesting to remember. Might have to invest in that gear myself!
Take it the Port is in the same location for all Mk4's (no matter what the engine size/spec)?
what else can you set then from the software
Suppose you also have a laptop, so its mobile and you can get it out to the car.
Or using the PC, you've need a MASSIVE long cable! :D
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
yer laptop is pretty much the only way to go. however my laptop battery is nackerd lol so involves an extrension cable lol. o and all ports on the mk4 are in the same place
