Need a p/n for the front fans behind the Radiator ( 2 of ) that would be spot on
cheers
mk3 caliper rebuild
has any one got a part number and a reliable source for caliper rebuild kit for front and rear?
Does anyone have the part number for the larger LHD wing mirror (drivers side in spain) tempted to try the 2 larger ones instead of the stubby..
aah, thanks for that, so i'd need
rear view mirror housing / for rear view mirror, electrically operated / use if required:
left lhd 3B1 857 521 3B1 857 521 A /
mirror glass (aspherical- wide angle) with plate / to be used for:
left lhd 6K1 857 507 N (01C) /
Anything else? :confused:
How do I get it primed or in flash red or do I give all the parts to a bodyshop?
you can get it primed but there's a specific part no for that,,,
I'm quite in a hurry so can't check everything but you need parts:
1 [which includes 3, 4, 8 and 9]
12 [the mirror]
13 [the cover]
all for the lhd left side version. that should be about it.
for the cover you'll need the part ending with the 'GRU' suffix which indicated that it's primed,,,
Is this the right Part No. for the rocker cover on a AQX engine 06A 103 469P?
Would a rocker with the part No. 06B 103 475L fit in it's place?
Tim
Just rang seat parts to order bump strips in black and allen key head bolts for bolt down coilpacks,
Apparantly the rear black one is 6K60 807 425 F B41 (he only had 2 in stock come up 1 grey 1 black though so maybe theres another one floating about without a number plate recess?)
Allen key head bolts are N 101 174 03 if they havent been mentioned already ( searched and found an old thread from philw mentioning them but dunno if they are in here )
Radiator mounts - answer from FL@PPER. Thanks again
N 101 638 01 top bolt *2 - £0.74 ea
1HM 121 267 top bush *2 - £3.38 ea
171 121 276D bush *2 lower - £0.47 ea
Dealer Prices.
Thanks for the list - am using it already!
Coolant / Antifreeze
Type: G 12 A 8 D (it's Red)
Specification: TL VW 774 D (on Bottle)
From Cupra owners manual.
Does anyone have a part number for the outside door trim from wing mirror to B pillar?
is that what this is :confused:
"Passenger side apperture door seal : S6K3867365G 15.41 + VAT"
its the passenger side i want not the drivers side in the pic btw
