Does anyone have a part number for the outside door trim from wing mirror to B pillar?
window seal scraper 6k3 837 477 left
6k3 837 478 right
stupid question but i just bought a mk3 ibiza cupra and want to get the centre capps off to see how many studs the wheels have....how do u do this, prize it away or sumhow get those annoying little screws out, tried an allenkey didnt work.
They are 4 stud wheels.
Between 2 of the 'screws' you will see a little hole. Put something (like a thin screwdriver) in there and gently bend/prise it off. Should pop off. Thats how I do it anyway.
jacko- think mr_r_devine just bought one of these. send him a message mate, and im sure he'll drop you the part number
no one ever sent me a pm. if you still need it i might be able to dig it out.
these are the part no for the vr6 clutch and g60 flywheel (they are the updated ones)
part no for the flywheel and bolts from vw (theres is cheap enough)
028105269bx flywheel £88.38 exe vat and £25 surcharge if not handin in exact flywheel.
The part no for the bolts is the same as old ones.
N10101001 & n90206103 x6each
Part no from euro car parts for clutch kit is
641440660 £64.16 inc vat.
i had the receipt in the car the other day. i will have a look for you tomorrow and see. and thats for the passenger side window? but bearing in mind there are 2 different kinds. one has 2 pin and other has 12pin connector!
Drivers side window motor: 6K3 837 402G
Maybe a stupid question but is the same code for the passenger side motor aswell? Also Ive read in other topic's using the search about the motor and regulator coming as one unit, is this correct??
