550's is pretty much the cut off point for high impedance injectors in this fitment, which give a perfect idle.
Baisically from there on you will start to have troubles with idle, even on perfect mapping, you just can't map the duty down low enough.
Having said that, 630's aren't too much of a
problem, you can usually up the revs a few 100rpm and have a tiny bit of overfuel.
750 genisis are about the same, due to it being a better injector design.
Then, from then on the higher you get the worse it getts low down.
Unless you run low's
Trust me, you won't get over 400hp from 550's without running silly pressures, or better fuel.
