Fitting Coilovers
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
hi all, as soon as the new year is here im getting my coilovers. me and my dad are going to fit them. Has anyone got any tips or hints for us please? and also is there anything else worth changing while were changing them?
many thanks
crezz :)
roly
midnightmotors.net
Jan 2, 2002
1,879
Midnight Motors Workshop
change the top suspension mounts and bearings while it's in bits
you'll also need camber/tracking checked and probably adjusted once your happy with the ride height
Mckellar
try getting a buzz gun..
those front top mount bolts are siezed to f00bar!!
well mines were.
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
soak in WD40 overnight, then just undo with a socket & allen key (7mm)
easy peasy on everything.
Airguns will most likely spin it up if seized
Mckellar
mines were possibly just super stiff.
airgun saved me a good bit of time.
changing the suspension is so easy though, easily achieved in an afternoon.
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
I also ended up using an airgun to undo the top nut, as it was just spinning up when using a spanner (didn't have a size 7 Allen key :doh: )
If you are doing it on a valver, its sometimes a little harder trying to get the whole wheel axle the right height (when one side still has standard suspension, and the other has a coilover being fitted), this is cause by the ARBs, so you will probably need a spare jack to lift the wheel axle to the right height. Or a REALLY fat mate when you are fitting standard suspension back on (when you take colovers off when you go to sell the car)
Mig
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
or just do both sides at the same time?
Not having the right tools explains the need to use an airgun
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
i think using an air/impact gun is more along the lines of having the right tools, messing about struggling with spanners and alan keys.
i used guns on mine, and the 2 bolts/nuts that hold the strut to the hub as they were fairly tight... o and i gunned the wheels off and back on, and yes i did torque them after :)
impact Guns 1... messing about 0
sjc59
Newbie
Jul 30, 2006
255
The only other suggestion would be to change your lower arms and all relevant ball joints and bushes i did with the girlfriends as if your other are in ok shape the coilovers being stiff will take there toll and you'll have to have it all apart to change them anyway.
