things you would need to do there may be more , i would say put it in neutral when working on it , means if you go to refit it you know its not in gear
- disconnect driveshafts
- disconnect clutch cable
- disconnect gear change rods
- unbolt from engine block
- undo gearbox mount and make sure you dont send everything flying as you pull it away from the flywheel
