things you would need to do there may be more , i would say put it in neutral when working on it , means if you go to refit it you know its not in gear
- disconnect driveshafts
- disconnect clutch cable
- disconnect gear change rods
- unbolt from engine block
- undo gearbox mount and make sure you dont send everything flying as you pull it away from the flywheel
Nope, can't get them and they don't plan to make them - not enough demand.
The website lies ;)
There is however one of the polo manuals which can be used for basics, but it doesn't give exact details
thx for the replies, just got off the phone to hallfords and there don't plan on makeing 1 for the lupo eather.
carnt find any think on the internet about a geat box :(
Hi m8, do you no if any of the engine mounts need to be lessened or tuck off to get the gear box off or back on ?
Have a look at the VAGcat site you will get a few diagrams and bits on there and you could cross reference that with the polo haynes manual.
hi,
the polo mk4 has the same gearbox layout.
i can print you out the vw removal procedure for the lupo or polo from elsa win if your prepared to send me a stamped envelope?
jochen.
