TommyCupra
Just Like That
Mar 30, 2005
217
West Yorks
Just swapped my modded airbox for a Jetex air filter and wow what a difference it made, tons more top end and it spins in 3rd now. Really shocked me, all i expected was more whooooshie sounds.
Anyone else got one?
Im running one, good bit of kit for the price too.. Did you fit a elbow to bring it closer to the wing?
how've you fitted yours?
I have a 45 degree bend from my old dynatwist but beacuse the end of that and the jetex are rubber you can't connect them securely?
I've tried putting a metal ring inside the jetex but then I can't fit the 45 degree bend over it :(
My application is like this..
Forge TIP, 70mm joiner to elbow, MAF, Filter.
cheers. i've done mine like this for now but the joiner i've used to attach to the filter is only about 20mm long although it feels quite sturdy.
benny has FC-07003 (out of stock when I ordered with approx 1 mth back order)
mine is a FR-07008
both rated to 320bhp
they are cheaper from europerformance
From what i have seen our ones are quite abit bigger than the jabba ones. I could be wrong tho im just going off of pictures ive viewd on the site.
Mine was around £46 then i had the elbow and joiner on top of that. I`d personaly recommend getting the joiner and elbow, as it looks alot neater and it brings the filter right upto the wing.
