Jetex Cone Filters :)
TommyCupra
Just Like That
Mar 30, 2005
217
West Yorks
Just swapped my modded airbox for a Jetex air filter and wow what a difference it made, tons more top end and it spins in 3rd now. Really shocked me, all i expected was more whooooshie sounds.
Anyone else got one?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Im running one, good bit of kit for the price too.. Did you fit a elbow to bring it closer to the wing?
Mar 10, 2005
1,439
Walton on Thames
how've you fitted yours?
I have a 45 degree bend from my old dynatwist but beacuse the end of that and the jetex are rubber you can't connect them securely?
I've tried putting a metal ring inside the jetex but then I can't fit the 45 degree bend over it :(
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
My application is like this..
Forge TIP, 70mm joiner to elbow, MAF, Filter.
1,439
Walton on Thames
cheers. i've done mine like this for now but the joiner i've used to attach to the filter is only about 20mm long although it feels quite sturdy.
Mar 10, 2005
1,439
Walton on Thames
benny has FC-07003 (out of stock when I ordered with approx 1 mth back order)
mine is a FR-07008
both rated to 320bhp
they are cheaper from europerformance
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
From what i have seen our ones are quite abit bigger than the jabba ones. I could be wrong tho im just going off of pictures ive viewd on the site.
Mine was around £46 then i had the elbow and joiner on top of that. I`d personaly recommend getting the joiner and elbow, as it looks alot neater and it brings the filter right upto the wing.
Jul 10, 2001
972
Bedfordshire
