CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
I have searched but i cant find anything on this subject. Maybe ive just missed it.
The heater in my car is quite frankly s***.
When its on number 4 it blows like it should, really strong etc. But on number 3,2 and 1 there is hardly nothing. There is alittle bit being blowen out but not much. Which means when the windscreen gets steamed up you have to run it on 4 all the time to keep it clear.
Is this a new heater motor or a new resistor? I know a new thermostat, could this be anything to do with it?
Price and/or part number for a resistor would be helpful.
Thanks All
Craig.
part number for resistor is valeo h17834912x
i have a heater motor for sale if u want it?
I also have this problem, on 3 + 4 my heater blows like it should, but 1 + 2 I get absolutely nothing! Any help would be appreciated.
try checking the heater controls. take of the fascia panel around the switches and check that the copper on the switch is connecting properly. if it doesent connect it doesent work! just try bending it in at the top with a srew driver. thats wat was up with mine and now works perfectly.
If its blowing on 4 and not on the others it will probably be your heater matrix (i think thats what its called). Its situated on the passenger side below the dash. Easy enough to replace and iirc about £30 from dealer.
Is that the actually motor or is it something different?? £30 is actually that bad. Think my local parts department will be getting a phone call in the next few days.
The part im on about is definitely not the the motor. If you get right under the dash (passenger side) you'll see it. Its a black block and you can see wires connecting to it. You can get better access if you take the glove box out.
apart from the controls playing up personally id say its the resistor/rheostat that is the block described above on the passenger side of the heater box
basically its a control unit that limits (resistor) the current to the motor and keeps itself cool by being in airflow
they are common for melting and as the pos.4 goes straight to the motor bypassing it its usually a sign thats its gone
the matrix is the radiator part so dont ask for one of them
Yeh wasn't sure what the part was called.
this is going to sound the roughest way ever but i had the same problem an as i was tring to get the face of the heaters off my screwdriver slipped straghit into my hand :doh:, i lost my temper an jst hit the dash on the top a few times quite hard :) then hay presto 8 stiches later an a good smashing the fan worked no prob never had a problem since :funk:
Now thats what i call 're-engineering'!!!
If you guys still have problems i have a complete heater unit with everything for sale (from a car with air con)
http://www.seatcupra.net/forums/showthread.php?t=153995
So it is the resistor that im after?? Is it an easy job to change it? My heater works great on number 4 but theres hardly anything on 1, 2 and 3. Breathing heavily yourself is probably more powerful!!
No mate. If it is the part that i mentioned then its an easy job. Literally unplug the old one and plug in the new one. DOnt go anywhere near the heater controls or facia. Like i mentioned before its on the passenger side, under the dash.
But i will just say that when mine went, there was no air blowing on 1,2 or 3 at all. Only setting 4 worked properly.
Well I'm certain i have the same problem as you did. I have nothing on 1,2 or 3. Only 4 works. The only air i get on 1,2 and 3 is the air thats being forced through with car moving. Nothing else
You dont have a part number for the part i need?
Im afraid not. I think it may have been covered a while back but i can't remember what the thread title was.
this is what you will be after my friend:
Same thing happend on my old Pug 205 - very similar unit stupidly fitted in passenger footwell. Of course, I didn't find out until I'd taken out the whole dash/heater/controls. :censored:
Whilst you're at it, its well worth changing the pollen filter. Makes a MASSIVE difference to the airflow when its dirty even when it doesn't look too bad.
