another penny just dropped----some of the Yanks were having trouble in cold weather with straight diesel this was a result of a too small orifice(no tittering at the back) in the pickup pipe because of the roll-over valve and clumping of wax, the cure is to drill it out, modified units have a suffix "H" in the part number and should be OKJust a follow up to my earlier posts on the subject of Veggie oil, been running my Toledo 110 on saisburys cooking oil for the last 13 months no problems driving ,no problems starting, only discernible difference was in the sound of the engine, gone was the 110 rattle, just a quiet BMW like BRRRR all the performance was there albeit 110 style (pocket rocket after 3000rpm but just a linear acceleration up to that point) BUT....here we have a week of cold minus temps just gone by....and so was the performance....oh she would start OK, took a bit longer to fire up but on the move...no boost, performed just like and SDI, so for all you VW brains out there, what sensor was causing the ECU to shut down the boost??? was it a temp sensor??? surely not because this was all the time the weather was cold, NOT just when the engine was cold. I checked everything all was OK.....but then, the weather got warmer and as if by magic back comes the boost .So how does the ECU know when to shut the boost down. (Just a note I never had this problem with a Rover 2 liter TDI but it did have a fuel heater in the filter housing and just shrugged off cold mornings) Also just lately I have played around with several borrowed MAFs and all of them give this same performance on my 110 all the real boost comes in after 3000rpm, I suppose a remap or chip is the only way I,ll change it?
how much should I start at???
Thinking chuck say 5L in when I fill up and see, or is less recomended???
cool, think ill give it a go once the weather gets a bit warmer. ive seen in a few posts talking about a Bosch diesel pump, why do you need to have a bosch one? and ive also seen people saying that the fuel filter has to be replaced more, is this still the case even if your just putting the odd bit in here and there?
also just wondering if anyone has a heated fuel filter in their car or if its even possible in VAG? i was checking out www.mercedes190.co.uk and some people there install heated fuel filters, wired to the fuse box in the engine and as far as i make out it thins the veggie oil as it passes through the heat.
so what is performance/mpg/responsiveness like on oil and diesel anybody?
if I had a 110 not"overtuned" and didn't paste hell out of it I would definetly use new oil in it to approx 30% and more in what we call summer, oil changes become more important and it would be good to know that the injectors were in good condition to start with ie if they were getting toward 70K (miles) clean and reset, the crap should be only on the nozzles and in the CC oil I guess start small and work up , however no warranty given or implied etc etc cheers Carlothe temps are getting a nice warm here and the diesel is getting way too dear,,, my mechanic is way skeptical abut using this veg stuff and says no fuel injector cleaner will be able to clean the crap caused by this kind of fuel,,, any comments about that?
