Dog bone torque settings
Mattman
Pob !!
Mar 9, 2005
81
ASTLEY
hi, please could someone confirm the correct settings for the dogbone mount on an LCR please, i have done a search and it came up with 30lb for the big bolts and 20lb for the smaller ones ??? i want to get it right first time around !!
thanks
matt
Cupra_UK
Correction Cupra"R"
Dec 24, 2007
217
Near Gatwick
Guys
I used this guide, http://www.ottawa-vdubbing.com/forum...ic.php?t=13397 to do it today,
why don't you just go on an in between torque setting, they are only suggested settings, i always go a tiny bit higher, a few NM just to put my mind at ease and my car hasn't fallen to bits yet, touch wood.
This is the guide I was referring to...
This might be a silly question but does a higher torque setting mean there will be more vibration? I would like to avoid that if possible.
DPJ, why did you change? Vibration? What settings did you have before?
rsmith
Robbie
Apr 28, 2004
2,796
Tipperary, Ireland
I used the setting DPJ just listed and found them to be perfect for me, i also increased my idle to 800rpm to avoid vibrations.
The compression bolt should be 12ft-lb and yes the tighter the compression bold is the more rigid the whole dog mount will be, this would suggest more vibration.
But hey, get the bushes on with the recommended torque above, run it in for about 200 miles and if you are stilll getting vibrations then reduce the torque setting by 1 or 2 ft-lb and see how you go then..
cruising03uk
street sleeper
May 10, 2006
133
north london
ok dog mount fitted imense vibrations in 1st 2nd and below 2500rpm so am i right that i need to loosen off the bolts a bit as its fitted perfectly just was in a rush so used a gun to do up bolts so probaly 100nm tightened up to????????
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Na you need to buy an INA track density DBM;)
Aug 24, 2007
800
The bolt that holds the bushes into the mount is the one that is critical.
If that is overtightened you will have issues with vibration.
The stretch bolts into the subframe could be fubar if the gun was set too high.
bonesfrench
76
Dog Bone Mount - Does it need to be insurance declared
just a quick one.
Are people declaring their uprated dogbone mounts/bushed with their insurance companies?
Should I be?
Please advise.
Ta,
George 3G
KW & Weitec
Jul 28, 2009
465
Herefordshire
can someone confirm the torque settings for a dog bone mount fitted with powerflex bushes please? Powerflex don't seem to state anything so I guess standard torque settings?
George 3G
KW & Weitec
Jul 28, 2009
465
Herefordshire
I now use the stock settings
Mount to subframe 20NM + a further 90 degrees
Mount to transmission 40NM + a further 90 degrees
and support bolt as above. (45 NM)
The support bolt being the horizontal bolt that holds the bushes into the dog bone?
The bolt shown below:
