RobboR
51
I cant clearmy fault codes with vag.com. itsays professional interface grade required?whats that?
also its not registered or activated.
I was led to believe with the shareware edition you can clear codes?
any help would be triffic
Should work with e-bay cable and share-ware vag-com. How are you trying to clear the codes (step by step).
Hi hairy
yeah im using the shareware 409 US one. i do my auto scan 1st, this brings up my error code.
then on the left menu i have print results, clear results, copy results and clear DTCs
after i click clear DTC i get the error professional interface grade required.
OK hairy il try that tomorow, any other way failing that? pulling battery?
Also have you registered yours? is this really needed? sorry all the Qs
Im sorted now lads, I cleared them after scanning individually like you said. Why these sellers never send out proper instructions??
Ahwell problem fixed and no light now! cheers
