my mates 130 ibiza
T. Spark
Your right about PD130 mapped V Std LCR (ish). Jabba's maps (not dissing them mind) and the rest yo!
john_tdi
mmm 385lbft
Feb 21, 2007
687
s wales
yeah but focus st are slow i know no body believes this but i beat the rs focus there uner powered compared to the lcr!!!
like i said james did stanard run of 15.2
i did 15.2 up santa pod too!!so what are people going to say to this??they shortened santa pod for me to make it fair??the normal one is the other person cant drive thats my favorite
Sorry a focus rs is 215bhp 230 lbft and it's near 150k lighter than a lcr. Most dyno around 230 standard. which means same power as lcr and more torque than a standard lcr, let alone the weight issue.
I can beat most things, provided im in the right gear, and I catch them in the wrong one.
T. Spark
And LCR come out on dyno's at 210/225bhp dead on dont they :whistle:
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
My 2p.
its not all about BHP figures its how the torque curve comes in and holds. Torque accelerates the car not BHP.
Ibiza and Polo's alike are light cars and once mapped will go quite quick. So keeping up with biggers heavier cars like Leons in gear near the ton mark is not uncommon and not suprising (i am not saying a polo can beat a mapped leon - i dont want to be involved in this arguement).
In fact it makes sense because for a car to pull ahead they must have quite a bit more power, like 25-50 bhp more. 10 BHP here is there might mean half a car length in a drag depending on driver skill.
As for bringing in petrol 1/4 times...don't bother their gearing is much more suited for 1/4 times.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Earlier scotty1 wrote
for example a map to produce 150bhp at only 3750rpm and the rest 110bhp is not as good as a map to produce a consitance 140bhp throughout the rev range
That would be a neat trick. The only reason for increasing the engine rpm is to deliver more power at the road wheels. If the power stops rising as you increase rpm, then you change up.
Power(bhp)=Torque(lb-ft) x rpm/5252
Torque peaks at low revs (1800-2200), then gently declines as rpm rises up to the combustion speed limit (for diesels) or mechanical limit for petrol engines, where the torque drops off like a stone. Once you run out of power increase there is no point in making the engine go round faster, so peak power defines peak rpm.
Peak power rpm is higher for a petrol engine. Away from the lights (i.e. at low rpm) the peak torque figure is a better indicator, as it occurs at low rpm. Diesels have more torque (they have higher compression ratios and make bigger bangs) so they match petrol cars with higher peak power figures.
Peak Torque
Code:
Car	lb-ft	@ rpm	=BHP
LCR	207	2200	87
LC	173	2000	66
TDI90	155	1900	56
TDI110	173	1900	63
TDI100	177	1900	64
TDI130	229	1900	83
TDI150	236	1900	85
So your TDI110 or 100 is comparable to an LC away from the lights. That's without factoring in the weight of the car.
Looking at peak power:
Code:
Car	BHP	@ rpm	=lb-ft
LCR	225	5900	200
LC	180	5900	160
TDI90	90	3750	126
TDI110	110	3750	154
TDI100	100	4000	131
TDI130	130	4000	171
TDI150	150	4000	197
The big difference is that the petrol car has to go to 6000 rpm compared to the diesel's 4000 - the diesel gets there quicker. Many petrol drivers never get to their peak power rpm because of the noise it makes.
In road-racing terms, where gearchanging and low rpm performance is important, the diesel has more grunt. But in most cases, these contests are decided by the ability of the driver rather than the car's absolute performance.
By the way, please publish when and where you are performing these "races" so that I can avoid the area. I don't want to be there when you have your accident.
StuPDi
old guy
Mar 30, 2007
203
Gillingham Kent
i used to drive an Ibiza 130TDi FR, and know for a fact from experience that from 70mph in 6th gear alongside a remapped LCR doing the same 70mph in 6th, the ibiza pulled away quicker to 110, then the LCR hit it's mark and left me for dust.
Also, i follewed a 225BHP mapped LC up quite a steep hill, and had to keep easing off, this doesn't mean if i was in front that i would have pulled away tho:(
when we stopped, the guy told me he was trying to get away, and asked if mine was a 160 or 180 bhp, when i told him it was a standard 130diesel he could not believe it!!
I now drive a chipped 130tdi Audi, and although i don't confess to be able to beat a lot, i can keep up with cars with a much higher power. Specially through corners ;)
Stu
StuPDi
old guy
Mar 30, 2007
203
Gillingham Kent
but did have 1 hell of a 130tdi ibiza!!!!!!
fair play for challenging, but the torque and weight of an ibiza are astounding!!
also, think about the powerbands and torque curves for both cars.
at 70mph in 6th gear, a mapped LCR is probably under the turbo and experiencing lag, hence why, when it started to go, i didn't stand a hope in hell's chance!!
all about reading the whole post, not just 1 little bit then flaming it!!!
Stu
T. Spark
so now its a standard 130 keeping up with a 225bhp Cupra!
What planet are you on!
Sissons mate, you have to remember diesel's are faster than ANYTHING yo!
What I find most amusing is the fact like myself, you have owned a 'tuned' diesel, and have figures to say exactly how fast it is 'legally'
But you dont like facts mate, end of! 225bhp Leons are slower than 130bhp diesel Ibiza's mate, word
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
This thread has gone out of control and is not constructive at all.
Lets put an end by saying, get that 130PD rolling road as it probably is remapped. If it is then we know why its quick.
john_tdi
mmm 385lbft
Feb 21, 2007
687
s wales
agreed, I'm supprised the thread has't been deleted.
Mar 8, 2007
831
Quick question...
If you want max acceleration from a pd130 60-100... should you keep it in 5th with your foot flat down or change up to 6th when you hit 3k revs?
Dec 16, 2007
432
Gloucester/Cheltenham
off topic : i would suggest booting it down (change gear) to get the most out of the turbo... you may loose a second though as your lowering the revs...
Think my 5th gear starts getting a bit sluggish past 80-90 (cant remember)
Though supose revving it gets the most BHP.
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
So the above doesn't mean you kept up with a 225bhp cupra...
