which means for the same initial valve lift the flow can start around the whole head of the intake valves/ex valves so flow is increased. 5v in a small combustion chamber makes for some crowding of the cyl walls
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
what boost do you want to run!?
I'm junking the VF34 and replacing it with a 16 or 18G from Blouch. I'm guessing I'll be running something like 1.5bar with it.
I've just read on a few forums that the standard compression is recommended for a street car with a medium sized turbo. Lower compression is more for very high boost and lowers volumetric efficiency. Net result is a drop in low end torque and later spool. Mine is used on the street and some drag runs so I want to keep the low end torque. A nice flat torque curve etc.
I'm thinking an overbore with standard compression is the way to go for me now.
Thoughts?
Just an awesome thread on explaing things..
So basically could I k04 or ihi my ibiza cupra with 137k miles on the engine...But do the genral maintance like cambelt,water/oil pump ect?
What miles is everyones 20v running on Bt?
Sorry to thread high jack
thanks
I'm sure you'll be doing it and have just missed this out as its not important but...These threads tend to go all over the place, but ultimately it's all good info.....usually
Just made a list of parts for mine.
Scat connecting rods - 144mm length 20mm gudeon pin
OEM head bolts - 10mm for 06A engines
Supertech intake valves - black nitrided (set of 12) (haven't decided whether I need these yet)
Supertech exhaust valves - inconel (set of 8)
Supertech valve spring and retainer kit
Supertech valve guides - set of 20 (just in case I need them, ebay them if not)
OEM oil pump - for 06A engine
Head gasket set - up to 82mm bore
Supertech pistons + rings - 82mm bore standard compression ratio (should equate to 1825cc)
Blouch turbocharger - TD05-18G
USRT Genesis Injectors (in case my 485cc @ 4bar won't cope)
Bosch 044 fuel pump
Comes to about £1800 from various sources. Majority from qedpower.com, but also from usrallyteam.com and blouchturbo.com.
Add £500 for those things you always forget.
