kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
www.wepaintanypart.co.uk
Misfire on idling
Hi all,
My car misfires when idling and gradually reduces rpm until about 500rpm where it tries to cut out and jumps up abit then cuts out. :( If I rev it hard to say 5k rpm there is no misfire. If I rev it very slightly the misfire gets worse
The car hasn't been driven for a while. Maybe a long drive could cure this and clean something out? Or is that not possible and maybe a component is failing? Idle control valve perhaps?
vag com brings up no errors for this. If I remove the maf sensor the idling cures very slightly but it still misfires.
Any thoughts would be great
Thanks,
Dan
if removing maf helps then change the maff, never hurts.
what engine is yours. and are you the same guy from Talk audio and ccuk?
:D.
I am Nutkin :p
anyhow, could be some spark plugs need changing and leads. heard them going a bit, coil packs too. have a lil search
I had a problem like this on my cordoba ages and ages ago, was oil on the air intake or something similar! I was 99% sure that this couldnt be the problem but my mate assured me it was and he actually was right for once. Probably not at all related, but figured id give my 2pence of knowledge.
Do you mean oil inside the intake pipe connected to the MAF mate?
yeah, or similar, seeing as the cordy i had was too old to have a maf it was around the location the MAF would be. To be honest though it doesnt actually sound (well to me anyway, and im just going by what ive read) that the MAF has gone. But who knows!
Hey,
Today I fitted another maf sensor hoping this would cure the irratic idling and overfueling problem - however it hasn't :cry: Unplugging the maf cures the idling but obviously it runs with severely reduced performance.
So can anyone suggest what else it may be? I ran a scan with VAG com and it came back with two faults: Coolant temp sensor signal too high, and lamba sensor signal too high
Many thanks for any help
Dan
i gave mine a good squirt with some carb cleaner, and its ran better ever since. Throttle body plenum covered in crap and not shutting/opening as efficiently as it should.
Jimski
DPJ, I spoke to a guy in the VW dealership and he said he's not heard of coolant temp sensor causing idling issues - only problems he hears of is issues with cold starting on diesels mainly. He does have them in stock - at £28.50! :O
Is a faulty coolant temp sensor actually known to cause rough idling? And why does the idling fix itself when I unplug the MAF if the MAF isn't at fault?
Cheers :)
