Geometry check - camber/tracking etc..
shantybeater
loving the whoosh
Sep 28, 2007
645
Bournemouth & Brighton
I just spoke to someone at protyre regarding a full geometry check & adjustment as they were recommended and they said it costs £30 per adjustment, I'm assuming this means tracking & camber so a cost of around £60 or do they mean like front/back? what is a full geometry check? isnt it just tracking & camber or is there more to it than that?
coxyboy
Ibiza Cupra R
Aug 16, 2008
191
W-S-M
alright mate ive got mine booked in with a garage in bridgewater for £75 but are recommended by the audi garage across from them.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
It will more than likly cost you the £75 for them to check it then you will proberly have to pay X amount per adjustment made.
Assuming your having it laser aligned.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Protyre when they have done mine before under my instruction on the badgerwagen was ~£30+vat for camber/tracking adjustment
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Looks like i got robbed then!
Im sure i paid a check charge and then an adjustment charge on top of that, came to about £102 IIRC.
RUM4MO
8,086
1,108
South Scotland
I think that your charging was "nearly okay" or depending where you live "okay" as they would have had to check the fixed rear was okay, check the camber/caster and toe-ing of the front and adjust it side to side to centre it to the rear. Four wheel alignment does despite what lots of people say, make good sense as its no good just whacking on new and maybe ungraded suspension components and expecting miracles to happen in the handling is the basic settings have not been corrected.
RUM4MO
8,086
1,108
South Scotland
Can't believe how much you get charged down there. The Time I got it it was around £20, mind you only for camber...
Well I'm just across the country from you and it cost £100+ a couple of years ago for a four wheel re-alignment for an Ibiza 6K at Seat (from uncle Arnie!) - where did you get your camber done for about £20?
