i swapped this from my spare engine earlier thought it could of been that as it came out of my old writen off cupra so may of been damaged inside but it was still the same
Yeah but when you disconnect the throttle body you need to adapt it using vag-com so the Ecu knows where its postioned
ok thanks all for your help it was doin the same thing b4 i swapped the throttle body as it was from my old engine which i crashed so thought it might of been damaged from that so it looks like ill need to get vag-com on it but it did cut out a few times whils revin it but not all the time
if u need some help mate give me a shout. i probably dont live far. and have full ross tech copy of vagcom availiable if you dont have it
Ecu is knackered would be my guess, have a search in my old threads i had it when i sold my revo ecu and the lad killed it on his car but vagcom will confirm
i was drivin the car the same day i took the engine out there's nothin wrong with the ecu, the ecu has not left the car just a case of gettin the throttle body aligned then.
gaz, got your message last night. I can do it, but I wont be home from work until after 7pm this week.
had 3 codes as soon as i started it up
17952- angle sensor 1 for throttle actuator signal to large
17581-shareware version to de-code all dtc's please register/active
17526-shareware version to de-code all dtc's please register active
so im guessin the 2 last ones are to do with allining the throttle body to the car and that the car is runnin 3" inlet so i think ill have 2 get the mapped ecu on and see if it works better with it on as the map with run with the mods i got cz now im tryin 2 get it to run on standard ecu!
The car would still run fine with the ecu with no map on, but might running it to limp mode coz you may overboost! just set the throttle body up.
i think its engine-basic setting-31(not sure on 31 if some1 knows please say)- it will the say adp runs-adp ok, thats it, sorted!
